Diy old school gas tanks
anickode
S.E. Michigan
DISCLAIMER:. HOME MADE GAS TANKS CAN BE DANGEROUS, PARTICULARLY IF YOU ARE INEXPERIENCED, IMPATIENT, OR SUCK AT MAKING THINGS. I TAKE NO RESPONSIBILITY IF YOU DO THIS AND BLOW YOURSELF UP.
Tin cans, as we all know, are not actually made from tin. They are made from tinplate steel. This means that it is very easy to work soft solder on it with a bit of experience. They can be joined to other cans, copper, brass, etc. Enter my latest little evening project, an old school gas tank for the rat wagon.
What I used:
3lb coffee can x2
Empty pvc primer can
¼" to ⅛" brass pipe bushing
60/40 lead solid core solder (like is used for leaded glass and electrical work, not plumbing)
Plumbing paste flux
Take one coffee can (or any can really, if you don't want a gallon tank) and decide where you want your fill cap and pickup bung. Drill a 1½" hole for the fill cap, and a ½" hole for the pickup.
Remove the top of the primer can (or any similar can with a screw-on lid) with a kitchen can opener (best done when the wife isn't looking) and shape the flange to match the curve of your can. Clean everything with carb cleaner and scotch Brite. Flux all mating surfaces with regular plumbing paste flux. Lightly clamp in place and heat the joint gently with a torch. Apply solder to the joint. It will wick into the joint. Let stand until cool.
Flip it over, flux the bushing and pickup hole. Insert, heat, and solder.
Clean the inside out. Plug the pickup hole and screw the cap on. Stand the can up on end and fill to the brim with water to test for leaks. Drain and dry if test is successful.
Using a "no sharp edge" can opener, remove the bottom from the second can. Clean, flux, and place the bottom of can 2 on the open top of can 1. Solder in place.
Test for leaks again, this time filling from the fill cap.
Rinse the inside out by putting some acetone inside and shaking it around, then pour it out.
Make a new gasket for the lid from cork gasket material, and drill a 1/16" vent hole in the middle of the lid, and poke a few pin holes in the cork gasket.
Congratulations. You made a gas tank the same way they did back in the hit-or-miss engine days. I learned this technique from an old-timer with a santa claus beard and overalls at an old iron show. Except they worked completely from scratch back then, and you dont have to.
And yes, I have made some gas tanks like this before, for old mowers and lawn tractors and stuff, and they all worked just fine. Even made a couple out of those rectangular F-style quart and 1 gallon cans like mineral spirits and Coleman fuel come in. (Those are a bit on the flimsy side though)
I did use a fine scotch Brite roloc disc on a die grinder to buff out and blend the solder a bit.
The can gets mounted with rubber padded straps.
echo7bravo
Five-Oh
Alabama
Beautifully done! With great talent and tons of patience, you have made something many will covet. Thought about making them to sell? LOL
KingCobra
TROLL CRUSHER INC.
TROLL TORTURE ROOM
Yeh, poke a few holes around the outer area of the cork so they don't line up with the hole in the center of the cap and that should be great.
nice indeed!
unfortunately coffecans around here are no longer a thing and they used to be a third of that size (500g to be precise)
Anyways.. I think I'll still keep that in mind in case I need to replicate that one day :D
anickode
S.E. Michigan
nice indeed!
The vast majority of coffee is sold in plastic cans here too. There are a few brands that still stick with the steel ones. Costco is where I get the big 3lb cans. It's good coffee too. Good enough it's worth drinking for the empty cans anyway.
Regular food cans work too. I know not many people buy #10 cans of anything for home use, but they are still everywhere in the commercial world. Or you can go to GFS and buy a 10 can of chocolate pudding and go to town.
One of my favorites for smaller tanks are the quart size Enfamil premixed baby formula cans. (We were swimming in formula cans a few years back) They're tall and slender instead of a typical short stubby quart can.
---------- Post added at 08:53 AM ---------- Previous post was at 08:52 AM ----------
Exactly what I did.
yeah regular food cans is what I was thinking as well;
Coffe-wise there are only few cans that are of reasonable size,
nice ones actually that directly screw onto your coffee grinder..
like this:
https://www.amazon.de/Moreno-Top-Espresso-Kg-Dose/dp/B01JVOLB80/
but as you can see, not exactly cheap (6+lbs is a nice size though)
there must be some "commercial" size food cans that are easier and cheaper..
most (if not all) are PE coated on the inside (to prevent food getting in contact with the tin can)
which is not actually beneficial when heating that thing to braizing temperatures let's say ..
but not all is lost (at least theoretically)
Maybe some Oil can (vegetable not mineral)
like this one:
https://www.amazon.de/Byodo-Rapsöl-nativ-Pack-Dose/dp/B003SLF7YW
or
https://www.amazon.de/Terra-Creta-Extra-Natives-Olivenöl/dp/B003UFDSPQ
or whatever...
we'll find something if we need to;
so it'll still be noted somewhere in the back of my head for future reference LOL :D
anickode
S.E. Michigan
No PE inside my coffee can :) Laws might be different here vs there. Some things are coated, and some things aren't.
Fortunately some stores especially Wal-Mart have nacho cheese and Ketchup in that style steel can. I think Jif Peanut butter can be bought in that type of steel can. So fortunately you don't have to just look for the nice coffee cans.
anickode
S.E. Michigan
But I don't need a gallon of ketchup or nacho cheese.
I DO go through a 3lb can of coffee in a month.
Although that does remind me of the time we shot a bunch of #10 cans of expired nacho cheez out of a pumpkin cannon at an old car
karl
North east Ohio
Thanks anickode !
My brothers fox needed a gas tank, and after I saw this thread I built by own!
I used an empty paint can, they sell them at home depot for $2. And a small can of pvc cement.
I used rosin core solder, it was sloppy and messy, so I just painted it.
I mounted it with a patch of stainless riveted to the frame, then a piece of an old serpentine belt with a hose clamp over it.
Not bad for $5 considering how much people want on ebay for them.
anickode
S.E. Michigan
Trying to decide... Paint or no? I'm leaning towards painting it red, with GASOLINE stenciled in white.
frankly, I'm leaning towards no paint...
then again if it looks like a small shell or pennzoil oil barrel after painting, it might be awesome ;)
anickode
S.E. Michigan
Ok next thing I can't decide on is mounting.
On top of the engine, and longitudinal
On top of the engine and transverse
Or behind the seat with nothing on top of the engine
The mounting height and the rake on the frame is enough to allow gravity feeling from behind the seat.
anickode
S.E. Michigan
Not sure why the pics are so fuzzy... The thumbnails looked good on my phone.
Redo of the one behind the seat, with nothing on the engine.
I think the tank itself looks best behind the seat, but the engine looks stupid with nothing on top.
anickode
S.E. Michigan
Top of the engine. Less plumbing and less need of a pulse pump.
I don't know that I would need a pulse pump. If I put it behind the seat it would be a bit higher than pictured (it's sitting on the pulley in the pic) and would actually be higher than if it was on top of the engine. Although hills would be problematic.
anickode
S.E. Michigan
Top of the engine, transverse. Final answer. Didn't have enough of the right size fuel line, but I had 1/4" OD copper, so I ran with it. It's a rat rod, right?
