Air filter adapter
Celeez
So i currently have a 900 series intek briggs & stratton its "apparently" the same exact block as a briggs animal and im trying to buy a new air filter but this is my stock carb what do i need to buy to get a k&n on here. please help me for the love of god.
I dunno, did you measure your bolt hole spacing to see if the specs match?
Then, after you fashion your little makeshift air filter adapter, you measure the outside diameter (OD) of the pipe and use some fancy google-fu to find an air filter whose inside diameter (ID) is the same.
Fleabay has a ton of air filters, both foam and the pleated fabric kind, a la K&N racing 'cone' filters with another bazillion different ID's...but they're ultra low dollar. You'd think there'd be just a few standard sizes but nope.
They have them to fit motorcycles, dirt bikes, scooters, ATVs, go karts and the pit bikes. They're just about universal.
Look what I found for just a 40mm ID air filter...https://www.ebay.com/sch/i.html?_odkw=40+mm+air+filter&_sop=15&_osacat=0&_from=R40&_trksid=p2045573.m570.l1313.TR2.TRC1.A0.H0.TRS1&_nkw=40+mm+air+filter&_sacat=0
Celeez
i dont have the bolts coming from my engine for the carb to slide on.(thats what i was calling mounting bolts) You can see that in my picture. Thats what i was calling mounting bolts. im pretty confused here i know nothing about engines. and im just trying to figure this out. here is the measurements of it
http://www.bmikarts.com/Air-Filter-...18FRe-CuZ4scwB_hgluKeIIMf4-Dn_wwaAvgDEALw_wcB
Call BMI. This is probably it.
1-(888)-926-6554
This billet aluminum air filter adapter is designed to fit 5 hp thru 6.5 hp Tecumseh & Briggs OHV but will work with many other engines. It allows you to install a K&N or simular foam type air filters to your engine.
Product Specs:
Measures 2-7/16" O.D. x 1" tall
Mounting holes are 3/16" and 1-3/8" apart
Works with all air filters that have a 2-7/16" inlet.
---------- Post added at 08:02 PM ---------- Previous post was at 07:54 PM ----------
Make sure you keep up on your weekly donation envelopes. The Vatican needs more money. It's expensive being so wealthy.
https://www.youtube.com/watch?v=lN1yHdFYdlA
