OK I thought I had this fixed but I guess not.
Googled it and found that the float needle seat gasket likes to swell over time with the ethenol gas. pulled the carb off and the bowl off and flipped it over, yep the float is not setting level its raised, gasket is swollen. No problem order a new one and replace it, float setting level now, good deal. Put it back together and same thing. I can only get it to run on choke setting 2 & 3 of 5. 2 gets it started after a pull on 1 (full choke). 2 chugs along for a few seconds until I move it to 3 where it runs pretty strong and it will run till its out of gas. But as soon as I move it to 4 or 5 it throttles down like its going to get to idle but keeps on going and dies. On 4 I can sort of keep it running by manually manipulating the throttle bar but a slight mess up will kill it. On 5 I have to give it a good amount of throttle to keep it running at all and if I barely let up on it it dies out and I can't keep it going.
I've cleaned it all twice now, new correct fuel filter, new needle float gasket, vented fuel cap, ran both with and without air filter, No change.
