My dual brake system
anickode
S.E. Michigan
Hooray?
I thought that was a fairly normal way to do it, assuming you're referring to putting a brake band around the clutch drum.
I built a kart many years ago that had the brake set up like this. I annihilated a sapling ginko tree when my chain fell off and I had no brakes.
So kudos on the double brake system.
Disc brakes are for cowards
I'm patting you on the back, real hard Goat.
Atta boy!
Using the clutch drum as a brake drum?--a model of simplicity.
Now your OTHER brake is just a nifty hand brake, right?
It's pretty bad when our moderators are cold and brutal. I thought that was MY job. :D
Goat
Retired for the grandkids
Northern illinois
Hooray?
. Zoom in on the pic and explanation. It is about a clutch brake with a scrub brake backup. Come on guys read the whole post.
---------- Post added at 07:18 PM ---------- Previous post was at 07:14 PM ----------
Atta boy!
. Thanks, close. Actually the clutch brake is my awesome and preferred brake. The scrub brakes suck and only there for an emergency.
Where's Chancer? He wasn't a fan of clutch band brakes. He'd tell you that if your chain goes, it is useless. But as part of a dual brake system. Ya it's ok.
MTNSleder
😈 Snake ƘƖԼԼЄ&
USA/CANADA
Better then my braking system :roflol: if you look hard enough you'll see a 2 x 4 :eek:
Hook up those tire cleaners and you'll have 3, that's got to be a record :D
mark your calenders girls...
this is the day the goat invented the brake...
hang in for a few more days though,
next it's going to invent the engine on a go kart...
PS next time, quote properly perhaps, an attached screenshot of a text is UNLIKELY to be read as you can surely tell by now ;)
Goat
Northern illinois
No, I really was wondering what was the relevant part of your post...
The relevant part is an easy way to add good brakes and keep your scrub brakes for a back up. If you enlarge the display and read the text you will understand.:backtotopic:
