How can i make my go kart climb hills better
Ahons
Bella Vista AR
Its got a 200cc engine and the kart weigh about 330lbs plus me about 210 it says the kart is rated for 800 lbs and the drive tires are 23in. The clutch sprocket has 14 teeth and the axial sprocket has 31 was wondering if changing the gear ratio would help and if so what should a change it to
What 200cc engine exactly is it equipped with?
Your typical starting ratio is 6:1 depending on OD of rear tires.
Awww, it's a cute little buggy. Two seats and all the comforts of a Prius.
You've got your sail foam turned the wrong way, btw. :D
Ahons
Bella Vista AR
Its got a Chinese made df motor and other then that i dont know much about it i couldent finde much els out about it
MTNSleder
😈 Snake ƘƖԼԼЄ&
USA/CANADA
Thanks.. maybe you can zoom out a bit, hard to tell what I'm looking at...
MTNSleder
😈 Snake ƘƖԼԼЄ&
USA/CANADA
This looks like like a torque converter or a gear reduction of some sort???
