Coffin Tank
GearHeadGarage
GearHeadGarage
Ohio
I'm working on my first coffin tank . I started with the size and degree of the backbone 12"long @ 17deg . I made a tinplate of what it'll look like. Then measured all the triangle connecting points. I done use the 3D in autoCad enough so the tape measure was quickest for me. I did put the sizes into a dfx file and burned all the parts out. Once together I'll measure for the bottom of the tank.
GearHeadGarage
GearHeadGarage
Ohio
Not sure I like it. But it'll work.
I guess it's still in mock-up stage and tack welded together, but do tell how you intend to blend and seal the edges.
With a weld bead and then ground down flush, or?
Looks fine to me. What could you dislike about it? ;)
GearHeadGarage
GearHeadGarage
Ohio
Fully welded , ground and buff ground. I have to make 2 new pieces and make the bottom. Then bung & valve
GearHeadGarage
GearHeadGarage
Ohio
One side bottom is done. Hope the pics from outside look better
I'll use a file to make the lines straight. And a lot of blocking primer
B.M.800
TheBeal.
Central PA
So Im curious... with a project such as this, pin holes can be a pain... how would some kind of solder go to eliminating leaks? Or brazing depending how thick the material is...
GearHeadGarage
GearHeadGarage
Ohio
First, you need to know how to Weld. Anyone can pull a mig trigger , but few know (how) to weld . It's all about how thick the metal is, the gage of wire , (hard wire with the correct gas for what your working on, and the correct temperature settings and wire speed.
I'm sertifid in stick, mig & tig ,, tig aluminum,, tig stainless,,
If it does have a leak I'll braze over it. And seal the inside of the tank.
