bbuckler
I got one sitting in the shop that I want to put on the next build. Anyone put one on there kart ? Got pictures ? I need to see how they hook up.
what do you mean "how they hook up" ?
it's fairly simple really
the longer shaft takes the comet driven unit (series 40 for example)
and a bearing (as a shaft support, the gearbox itself is too weak to do so in its own)
the shorter shaft takes a sprocket that in turn connect via chain to the axle.
the lever controls forward neutral reverse and should face up
(that way the gearbox essentially sits behind the engine , not offset)
here's a quick guide (incl a drawing of the setup)
http://www.geminikarts.co.uk/files/Comet-FNRGearboxDimensions.pdf
I would really would like to see how someone did their shifter
Thats a different beast entirely,They use a motorcycle engine.... still no reverse...
