Kleyny
I have aligned my sprocket up as best as I could without a laser by using a straight edge and is running parallel to the axle
As long as I'm not turning hard and sharp it seems to be ok. As soon as I load it up by turning hard and full throttle it pops off.
I have taken the engine off to check if the engine is sitting level with the axle and found that the engine is tilted down 5mm from the flywheel side to the sprocket side.
I'm hoping this is my problem.
Will a 5mm angle make the chain pop off?
Thanks
Thanks
