Kart still throwing chains
Kleyny
Brisbane Australia
I have aligned my sprocket up as best as I could without a laser by using a straight edge and is running parallel to the axle
As long as I'm not turning hard and sharp it seems to be ok. As soon as I load it up by turning hard and full throttle it pops off.
I have taken the engine off to check if the engine is sitting level with the axle and found that the engine is tilted down 5mm from the flywheel side to the sprocket side.
I'm hoping this is my problem.
Will a 5mm angle make the chain pop off?
Thanks
Staff Murderator
^^ What he said.
Also, what comes to mind is a slight shift of your axle (and your sprocket) sideways, as you're making a turn that would be enough to throw a chain. This could be due to worn bearings, loose axle spacers or lock rings that have too much slack or are not snugged up.
On the extreme, you could be dealing with some or all the above plus a sprocket that has a burr or nick on it causing the chain to derail, as well as a defective/mangled chain that pops off when the right conditions are met. Check both for any defects.
Ever heard of sprocket guards? They are meant to protect the sprocket teeth from chewing up the ground, or pebbles, stones, gravel from damaging it.
I will quote anderkart: "(another huge advantage of using sprocket guards is they make it nearly impossible for your chain to come off...)" ...http://www.diygokarts.com/vb/showthread.php?t=11258
firemanjim
Just kartin' around....
Houston Texas
Could be as simple as the bearings are worn allowing the wheel/sprocket to lean in a turn. I don't know what kind of kart you have....
Kleyny
Brisbane Australia
The whole rear end of my kart has more hits that Elvis.
Things just magically happen when someone else uses the kart. Anyway that's a different story.
Waiving an angle grinder and welder around I have been able to fix, strengthen and realign the rear frame. However I did not notice the engine leaning over 1/8" to one side.
Come to think of it Qtband the engine mount I made to fit the TAV flexes quite a bit even squeezing the chain together by hand makes the mount flex.
There is no movement in any of the bearings and or spaces so i think im safe there.
It could just be the cheap and nasty chain that I bought as well I guess. I plan on buying a RK or DID in the very near future now that I'm happy with the performance of the TAV.
I was going to go back to just a plan old dry clutch but after eating my friends kart alive with the TAV I'll stick with it and get it right.
So Ill build a whole new engine mount and fix up the angle to the side and the flex and see how I go.
Thanks
Mckutzy, I dont think I have any photos with the TAV on it I'll have a look on my phone, even if I do they wont be close ups.
Staff Murderator
You mini bike guys are just cheap and destitute. Can't afford two more wheels, a backrest and the extra tubing for the frame.
Cheapskates!
. . . . . :p
Kleyny
Brisbane Australia
I'm guessing everybody like the USA and China, hates you guys!:p
Lol 99% of us even hate our politicians.
But most of us average Aussie aren't too bad. Ok ok some aren't too bad.:lolgoku:
---------- Post added at 05:14 PM ---------- Previous post was at 04:49 PM ----------
I just had a look at the kart suppliers web page and his replacement chain is a #41.
I am under the impression that the 420 chain is ok to run as well.
Is this correct? 420 chain is more prevalent here in aus.
Thanks
