Steering is very touchy
Everett45
Idaho
My go kart has very crude and rudimentary steering. On my one and only test drive so far, I noticed it is rather touchy at higher speeds (I only got up to 20-25 mph). Based on my current setup, could I 1. Modify it to have less wheel turn per steering input? Or 2. Ditch the sketchy setup and install something new?
Staff Murderator
Ditch it all and get some decent adjustable (threaded) tie rods with the ball and socket ends, i.e. "heim joints".
That looks unsafe and I see a lot of slack and loose fitting nuts and bolts.
You should also have a slight bit of toe-in for best performance.
Everett45
Idaho
Thanks for the input. Could you recommend a specific set I buy? I'm not familiar with the parts I will need. Also, for a size reference you can see the 36" axle back there with red hubs on it.
Ebrownie
Western Montana
Well, there are many places you can get a set. Bmi, gopowersports, eBay, etc... or you could buy some heim joints (rod ends), 3/8" steel rod, and a die to thread the rod. Depends on your tools and if you feel like making them yourself.
Everett45
Idaho
I've come up with a sketch of what I want to do. If you look at my first photo, you can see right in front of the pedals where the sheet metal ends and the angle iron is attached, along with the front axles. I'm going to cut along that line, severing it completely. I will cut off the little front bumper to reuse it. I will then attach square tubing where the angle iron was, and on either side of that the axles. Tell me what you guys think. What is a good way to secure the axles, insuring they are straight as well?
Flyinhillbilly
The great cornholio
North West Arkansas
The best way to make sure it's straight is to set it up off the ground on something stable, then drop a plumb bob from the bottom kingpin hole and the center of the rear axle and measure it in an x. When the numbers are even, it's straight.
tinamcjittles
ello m8
Allovau
Alright, so if you're doing all of this work on the steering you might as well flip the spindles around so that your steering mechanics are all behind the wheels.. It helps with a lot of things; a lot of people don't consider that each wheel is traveling in a circle of different radii, your inner wheel needs to make a sharper turn than your outer one. This sounds useless, but it helps with that snow plow effect! Google "ackerman angle", "king pin inclination angle" and "frame jacking". You'll start to appreciate enginerds a bit more lol
Staff Murderator
On further examination, your entire front axle and spindles are almost completely FUBAR. None of the spindle or kingpin angles match and the front axle appears to be bent on the left (and out of plumb elsewhere).
More photos are needed (top, side, rear, etc.), or you just need to recognize for yourself that you might be better off replacing or fabricating the entire front end. The front axle needs to be made of thicker, stouter steel tubing as it is a load bearing element. Buy some factory-built spindles as the ones that exist look either homemade and/or repaired several times over with gloppy welds.
I'd prefer more photos--looks like a fairly unique kart.
Forget about Gewgling--our site FAQ & Articles should have everything you need to include the Helpful Links From The Forum thread.
Everett45
Idaho
Hellion, that's exactly what I'm thinking. My order of new spindles, brackets, tie rods and ends arrived by te end of today. I'm going to pick up some beefy 1x1 square tubing, and fabricate the entire front end. I would like to cut past the pedals, as they are very loose and sketchy, but I'm not sure how to go about fabricating new spots for those. I would have to put in very short lengths of tubing and sheet metal to replace what I cut off. You can see in the picture, the tubing where the pedals are located is fairly boogered up as well.
Staff Murderator
Sounds fantastic.
I'm not certain but it looks like the front axle was designed as a drop axle; that is, the spindle ends had a down angle on them lowering the chassis for a lower center of gravity, better handling and such. You could attempt to replicate that on your kart or just make it flat.
Depending on where you intend to drive, that could be a good thing (flat dirt, pavement) or bad if you wanted more ground clearance.
I saw some pedals for cheap at BMI that were designed to straddle the tubing they're mounted on.
Clean up the welds there with a grinder and/or add a bushing if it's sloppy there and voilà.
http://www.bmikarts.com/Right-Left-Foot-Pedal-Set_p_3729.html
Everett45
Idaho
So I've been researching a bit more for my upcoming fabrication project. I completely blanked on any camber or caster implementation, as the Kartfab.com website had the steering setup at all 90 degree angles, no caster or camber. I realize that these may in fact be necessary. My purpose for this kart may include pavement (not tracking), gravel, dirt, but mainly off road-ish. Can I get some pointers for how much of which to do, and if I even need to? I've included a quick paint sketch of my thought process and visualization.
PredatorPowaaa!!
Mistake Maker
Ontario,Canada
so thats why my dingo looks like it has camber.
Staff Murderator
... Can I get some pointers for how much of which to do, and if I even need to? I've included a quick paint sketch of my thought process and visualization.
I don't think you need (or want) any camber beyond 0. This is only adjustable on your front end, sadly, so the 0 camber at the rear wheels might make any camber angle you add on the front rather negligible.
Positive caster might be worthwhile if you want that straight line tracking that nearly all automobiles have and want your steering wheel to return to center upon release.
My opinion only, your mileage may vary. What does the rest of the forum have to say?
Everett45
Idaho
Good point about the camber; I think I'll leave it be. As for caster, it sounds like I should do a bit of positive. I'm still open to feedback, I'm putting this all together on Saturday.
Everett45
Idaho
I just got my square tubing, and I went home and mocked up my spindle brackets. I took a little protractor, and at 10 degrees it looked about right. What do you guys think?
Flyinhillbilly
The great cornholio
North West Arkansas
10 degrees of caster is ok, but I think 12-15 would be better. If you really want to get down to brass tacks, you should have some steering axis inclination as well. Fwiw, I do front end and suspension work for a living and have for the last 21 years.
