Racing cart
zanegrey
zanegrey
n.ky
my cart
zanegrey
zanegrey
n.ky
Have taken off 270 with tav and put on 212 cc engine .
Have it all set but all of a sudden the engine has too much compression to pull with starter rope.
I did not have time to check it out..so asking if n e 1 out there has an idea what this is??
Thank you
Maddog McLane
Wisconsin
Thank you
Try checking the valve clearances??
Leaking carburetor has flooded the cylinder with gasoline?
Pull out the spark plug and if the recoil starter operates, pull it vigorously several times to dispel the fuel.
Flyinhillbilly
The great cornholio
North West Arkansas
Pull out the spark plug and if the recoil starter operates, pull it vigorously several times to dispel to the fuel.
If this is the case, make sure the plug wire is where it won't spark in anything. I nearly blew my face off doing this once. Fortunately the security camera caught it and I was able to get video.
https://m.youtube.com/watch?v=ZS2G3Jnp3JA
zanegrey
zanegrey
n.ky
I am taken back to...
A time (being 60 ish) that we made our karts out of grocery carts ,rider frames and refridgerator doors..
We called them carts .we did not kare about writing..
---------- Post added at 12:11 PM ---------- Previous post was at 12:10 PM ----------
And thank you all for the comments...
I don't care if you're 6 or 60, anyone using shopping carts for frames most likely stole them!!!
Care to explain how those transactions went , and what you paid for those "carts"?
BTW..I was born in 1956, (if you paid attention in school, you outta be able to figure that out.)
We like the kart just fine....It's YOU we can't stand!!!
Actually, you'll find we like to BS a lot....so...no problems....IF!!! ...you can put up with us!!!!
(I I hope you realize that we DON'T dislike you, we are just jerks that like to jack around!)
zanegrey
zanegrey
n.ky
it appears the exhaust valve push rod came out of position ..
I reseated it and gapped it and it is running just fine..
thanks for the comments..
I rode it in front a a police speed trailer.
it posted 52 mph twice..
That happens pretty often...( not getting clocked by cops....) but those pushrods running away from home.
