212cc predator header pipe
Hello and Welcome....
Since your new here... Howabout you give more info on what headder exhaust you are referring to, as in a pic or a link, or both...
Along with a performance air intake/filter, larger carb jets, and advanced ignition timing... 2-3HP???
KartFab
weenie pipe header, not much, but you can retain a lot of the torque you would lose on a large diameter open header at low rpms.
open/multi stage header will be less restrictive at high rpms, and (combined with other modifications) will allow the engine to rev up to higher rpms not attainable with a weenie pipe or stock muffler.
So if you are just starting out, most people that do modifications, do them in stages. If you are going to get a header, you would probably also do what bob580 mentioned in order for it to make a real difference in power.
lance fewell
thanks
im only 13 so idk that much about go karts. i bought a regular header pipe from gopowersports. can anybody tell me how to get more power out of the motor it is a 6.5 horsepower predator and im trying to go faster so i can race.
Flyinhillbilly
The great cornholio
North West Arkansas
Search man, this site is loaded with hot rod predator builds.
Tom Knight
Metal fabricator/welder
Sunny Las Vegas, NV
Good to see young guys on here getting their feet wet in mechanics, welcome and let us know how you make out, some pics of your kart & what you want to do with it will help....
Staff Murderator
I constantly reference this thread when people ask for what gains a performance header (three-stage in this case) will give them over the stock muffler. Even though it's for a flat head Briggs, it shows a wild jump in HP after it is added.
Like the author mentions, a similar dyno-tested OHV Honda/Clone build-up would be most welcome.
