Drive train for fuel efficiney
1anas16
Hello every one, this is my first time posting.
I would like to start off by saying this forum has been very helpful for our build.
We are building a supermilage car for shell eco marathon that is based off a go kart, for example the entire steering system and drive train.
Our engine is a 4.6 hp hatz 1b20 diesel, with a 3/4 shaft. So its very similar to other gas engines.
However, i am looking at this from a fuel efficiency standpoint.
we are planning on using a jackshaft because we have one rear wheel ( 3 wheels on the car) and the sprocket on the hub is on the right side. So that is major power loss. I was wondering if a direct drive would be feasible rather than a clutch. We are staying at 2500 rpms as that is most torque and least fuel consumption, Our goal is using as low amount of fuel as possible, speed does not matter. So staying at that rpm I am worried that it might burn out the clutch. the engine comes with electric start so we can start it right up and for the majority of the time the engine is going to be turned off. In addition I was thinking that a direct drive would have least power loss ans there is no friction and slippage.
Would we just add a 3/4 keyed sprocket with shaft collars on the side to the output shaft?
The wheel hub has a clutch like any other bicycle would. so we shouldn't have any problems with engine strain.
Its also a very light frame made of carbon fiber.
I want to hear peoples thoughts on this, and if direct drive would be the best idea. Feel free to ask any questions.
:kewlsmiley:
Flyinhillbilly
The great cornholio
North West Arkansas
I say aeordynamics, aerodynamics, aerodynamics. Get the driver down out of the wind, streamline everything, make sure your toe is dead ahead with the rider on board, and you can't go wrong with ceramic bearings.
1anas16
Thank you, I completly forgot about using good bearing. As for aerodynamics, there is a enclosure that surrounds the entire vehicle. It is a teardrop, or raindrop design. It is designed in a CAD by our chassis sector, and we are looking into getting it tested with a virtual wind tunnel. However I do now know much about this.
Kleyny
Brisbane Australia
I could be thinking down the wrong path here but isn't a hub on a bicycle free wheeling on neutral pedal or backward pedaling? So once you start your engine that bicycle hub will always be engaged.
I think you have no option but to run some kind of clutch on the engine unless you don't have to stop with the engine still running. You can purchase dog clutches that won't slip ( they work with a cable set up) this I think is your best option you can the engage the clutch at any rmp. You could probably make your own dog clutch to suit your needs easy enough.
1anas16
Yes it is free wheeling when the pedal is neutral. Teams use a technique where you get up to speed then turn off the engine and coast until more speed is needed, so we are allowed to turn off the engine as we please.
Ill look into the dog clutch, seems like a considerable option. Thank you very much!
This is a diesel, itll be quite alot of power consumption for starting motor for start/stop operation. You cant really pull start them easily, cause of the compression ratio...
I would say running on/off alot will be a detrimental to the efficiency overall, needs a biig battery for good charge..
Kleyny- What is/are these particular cable actuated dog clutch you are referring to? link..
Done extensive research over the last number of years... cant find something like this.....
Manual clutch yes, restart engine yes.. battery no!
(terrible weight addition)
instead elongate the starter cord and hook it up to your foot (stirrup) to basically make a "kickstart" it might be inconvenient, but better than adding the weight of a battery or yanking your arm out trying to start it sitting (or more likely laying) down ;)
you need a topological track profile and the best possible weight estimate to adjust your gear ratio to the highest possible, that way the eninge will push you furthest per rotation without suffering;
but take off will be a pain.
flip the rear wheel if possible.. adding a jackshaft is not a good idea
it adds weight, it adds a set of bearings and thus it adds unwanted friction;
and even with high quality bearings you'll loose roughly 2% of your engines overall efficiency (guesstimated value),
which doesn't sound much, but participating in an eco marathon it's a ton!
So flip that rear wheel at all costs (but weight)
weight reduction needs to be your top priority I'm afraid (that's the most expensive part of it all)
I assume you'll use bicycle wheels anyways, and depending on the weight the fixed engine rpm...
I think you could even try to pull it off with bike chain here... (skinnier thus lighter chain and sprockets)
and bike chain fits a #41 sprocket for your 3D motorsprt manual clutch (which is indeed the way to go here IMHO )
but test that first!
(hook up the engine to an old brake disc and have the caliper slightly engaged to emulate load)
it doesn't matter if it's worn out and done just as you cross the finish line if it saves you some more weight.
bicycle wheels I hope or the smallest, skinniest and lightest wheels you found to be feasible at least.
half of all rotating mass is constantly working against you (and reducing your mileage)
worse the faster it rotates and/or bigger its diameter...
that's why a running engine (not actually powering the wheels) will work against you
and restarting it is actually a good idea.
all miniscule amounts.. true but they add up... and taking that into consideration can pay off.
