Spend My Money!!!!!!!
outcrydrummer
KART ART
Greensboro, NC
I've decided to just create this thread instead of piggy backing on multiple threads.
GOAL:
To turn my predator powered race kart into a tire smoking, draw dropping, yard ripping, chick magnet.
CURRENT STATE:
Predator 212 specs.........
bully 2 disc racing clutch
stock head
stock valve train
Mod 2 cam
ARC +.020 billet rod
.650 ruxing carb (22vm mikuni already on order arriving 2/6/2017)
open header
open air intake
Piston in hole .025
Clayed with no head gasket with .080 valve to piston clearance
Head gasket ( Fire ring .045)
Stock flywheel (I ordered the wrong part number first time around )
I'm slightly concerned with the current crank as I saw some heat discoloration on it.
Thinking I should order a new crank, + .040 rod, and a .019 MLS head gasket.
I tried the metal .010 and it didn't seal worth a crap.
That would get me .005 in the hole and I would have plenty of piston to valve clearance.
The Question Is
What would you buy??
My current this week spending limit is right around 250 bucks.
---------- Post added at 02:05 PM ---------- Previous post was at 01:34 PM ----------
Another option I was considering....
I have another predator that I removed governor on but otherwise is stock.
I could just transfer over a few parts and then I don't need to worry about buying a new crank.
I could just order this:
Black mamba cam
split keepers and retainers
+.040 rod (Have to pull head tonight to verify deck height first)
.019 mls head gasket
billet flywheel
Install the vm22 on this engine
Install open header on this engine
Then I just leave the other engine alone with the mod 2 cam in it, the .650 carb, and open air filter and put that on the drift trike (where the new stockish engine would come from).
outcrydrummer
KART ART
Greensboro, NC
I want to stay with Gas that way I'm not changing the oil every other weekend and don't have to worry about specialty fuel outside of something like 93 octane.
The head seems legit..... have to see what they run and what the bang for buck is. The stock head is what?? 22 cc?
Flyinhillbilly
The great cornholio
North West Arkansas
No idea. I'm going to put a ported big valve 14cc on mine and switch it to alcohol, but I'm not going to open the short block at all. I'm curious how much power these can make on an unopened short block.
outcrydrummer
KART ART
Greensboro, NC
They want too much money for a head so i will just get one of mine milled and ported.
I went a little over my budget but here is what i got.
The pics are whats in my parts list so far.
Black mamba jr cams are finally back in stock :)
tinamcjittles
ello m8
Allovau
Make your chick magnet a stroker with so much compression you don't even need a spark plug.. maybe 21:1?
Can't wait to see where you take this engine!
outcrydrummer
KART ART
Greensboro, NC
LOL!!!!!!
I'm shooting for 11.5:1 or somewhere in that area.
My ultimate goal is to make as much useable torque in the mid range as I can.
But yeah anyways I'm shooting for sub 7k rpm power. I'd love to make most of my power between 4k to 6500rpm. Definitely needs to be able to run on pump gas. I'm hoping by keeping the RPM's low I won't need an insane amount of valve train parts to support it.
I went ahead and ordered the black mamba jr cam
The 0.019 70mm bore MLS head gasket and the billet flywheel. I'm not worried that the flywheel will come apart I'm really just curious to see if it's noticeable how fast the engine spins up with the lighter flywheel......
I kind of want to see if the .020 rod and crank hold up at this point.
I'm gonna sleep on it tonight and possibly just order the crank and the +.040 rod in the morning.
outcrydrummer
KART ART
Greensboro, NC
Kartorbust I thought about doing a smog pump supercharger honestly but not on my race kart. I'm doing a mini bike build here next month and I've really considered it for that.
I really don't want to have to mess around with a turbo though...... re-routing exhaust to drive it, boost lag, and oil supply are all going to be a pain in the butt on a predator.
18cc IIRC...
There's the key, use the big valves; the smaller combustion chamber increases compression & the bigger valves keep the original flow (which, I'm sure, you know), porting & polishing increases that flow...
Here's a quick tip: Do the port work before the valve seats; nothing worse than knicking one of the freshly cut valve seats while polishing the ports ;)
My engine, with these mods, although only being a 160cc, is a torque monster, I can only imagine what it would be like if it was a larger bore 200cc...
Flyinhillbilly
The great cornholio
North West Arkansas
18cc IIRC...
I found the easy button on heads. I just pay someone else to build them for me, lol.
