tinamcjittles
ello m8
Hey guys, after getting the kart driving again recently I discovered it has a horrible throttle surge at high RPM. It will stall completely until I close the throttle, at which point I replaced the carb because I figured it had to do with the venturi. After swapping carbs I went out for a ride, then it started doing it again! After hearing it backfire a few times I thought maybe it was a valve lash/timing issue but I checked that and it all seems perfectly normal!
If any of you have had this issue and know a fix that would be awesome.. The surge gets so bad after it warms up that it wont have the power to get itself rolling :/
Thanks,
Tina
Oh, also, I just put a resistor spark plug on to fix the RF noise problem. It runs amazing without any load but as soon as I attach the chain and go for a ride it starts up again
Edit: sorry for posting the thread in the wrong section yesterday, but I can't delete it hahaha
Thanks,
Tina
