Engine Problems
tinamcjittles
ello m8
Allovau
Hey guys, after getting the kart driving again recently I discovered it has a horrible throttle surge at high RPM. It will stall completely until I close the throttle, at which point I replaced the carb because I figured it had to do with the venturi. After swapping carbs I went out for a ride, then it started doing it again! After hearing it backfire a few times I thought maybe it was a valve lash/timing issue but I checked that and it all seems perfectly normal!
If any of you have had this issue and know a fix that would be awesome.. The surge gets so bad after it warms up that it wont have the power to get itself rolling :/
Thanks,
Tina
Oh, also, I just put a resistor spark plug on to fix the RF noise problem. It runs amazing without any load but as soon as I attach the chain and go for a ride it starts up again :(
Edit: sorry for posting the thread in the wrong section yesterday, but I can't delete it hahaha
PredatorPowaaa!!
Mistake Maker
Ontario,Canada
Have you done anything to the gas tank? (Like have you mounted it somewhere else) because I'm thinking it sounds a bit like a fuel delivery issue. Also, tell me about the whole resistor thing.
tinamcjittles
ello m8
Allovau
Nope no gas tank movement or anything.. The spark plug I had on it was not a resistor plug so when I'd start the engine the throttle servo would jump around and have huge potentials on the signal wire. It was nearly destroying the microcontroller so I did some research on how cars avoid this type of problem with computers and the use 5k Ohm ceramic resistors in the plug. That slows down the energy flow to the plug and makes the arc last longer which flattens out the nasty waveforms that kill electronics. I tested the engine without the chain attached (no load) and the spark plug works perfectly without any misfires.. :/
tinamcjittles
ello m8
Allovau
Servo??? Microcontroller??? What kind of go kart are you building??
At this point... A science experiment lolol
The more the merrier :D
I want to get the Raspberry pi on there for some wifi but I need the linear actuator (not cheap :mad:) for it to steer itself..... Then it should be the first wifi enabled self driving go kart *evil laugh*
tinamcjittles
ello m8
Allovau
Ahhh. Okay I see. Sounds like a blast! Are you in the kart? (When it is driving I mean)
Lol yeah I have to be right now but hopefully later it will steer itself :D
It's not complicated at all to make actually, it just flippin took forever to wire! Turns out HDMI cables work great if you need like 20 wires in one hahaha
Do you think it could be the fuel sloshing (scientific term) around in the tank? Right now that seems like the only possibility but I'm just outta ideas lolz
tinamcjittles
ello m8
Allovau
Good idea with the HDMI cable! Yeah it would probably be a mega pain to run wires. I agree linear actuators are **** expensive. Is it a predator 212?
It's a Gx160, but they're like the exact same thing lolol
Yeah dude for like a motor and gears with a shaft they want $100! as if!
Bbqjoe
Banned
Location, Location
Haven't you figured it out yet????
Almost every engine discussed here is a predator.
As a matter of fact, if it weren't for the obvious connotations, They were going to change the name of this place to "Pedators R US"
PredatorPowaaa!!
Mistake Maker
Ontario,Canada
Not a bad idea with the new spark plug, but the thing is already all wired up and sounds like it took a while so it might be annoying to change it completely
tinamcjittles
ello m8
Allovau
Have you tried a different spark plug?
Maybe use a power window motor from a car for steering? It could work with a bellcrank I think.
I can go buy one but if it isn't a resistor plug the servo gets so much interference it goes to full throttle all the time :roflol: would kinda suck
But that is an amazing idea, I got a few junk yards in mind already ( ͡° ͜ʖ ͡°)
I'll post it on here if this thing works well!
---------- Post added at 03:39 PM ---------- Previous post was at 03:38 PM ----------
Yeah I won't be takin' all that stuff off anyytime soon...
---------- Post added at 03:40 PM ---------- Previous post was at 03:39 PM ----------
Hmm
Sharkasm aside you're right, and they're getting old lolol
Rail rider
Inmate # 3192016
Planet earth ( the flat one)
Banggood.com has the pi and a lot of other project parts. All the WiFi components and F.P.V Cameras and glasses. If you are into riding around the block via wifi . linear actuator...that's a funny name for a wind shield wiper motor
Randy H
Thanks,
Tina
Fuel tank vent?
