TC driver weights
Bbqjoe
Banned
Location, Location
On the weights there are two raised lands facing the cover.
Anyone care to explain their purpose, and if it means anything when they're about gone?
FreeRunner15
They just engage the motor to the wheels.
Now the weight of the weights help factor what RPM the TorqueVerter engages at.
That coupled with stiffer garter springs an you will have a ground rocket.
Or a drift machine.
Or burnout king.
Tire frier . lol.
edit: just realized you were only talking about the face of the weights. oh well, enjoy my post.
Bbqjoe
Banned
Location, Location
that's a wear mark nothing more really.
telling you when to replace the weights.
I've looked a bit online, and I have yet to find a perfect explanation of how the driven works.
It appears to me that obviously the lands or marks or whatever wear down.
When the weights expand against the driver cover, or hub, the lands would be the only thing in contact with it.
So, if they wear down, then the full face of the weights then is in contact with the cover.
Are the lands the only thing that wear out?
It appears the metal rods don't.
What's actually gripping anything?
If the lands were built up, and reshaped, would that "rebuild" the driver?
I think this whole thing requires further investigation.
the weights are a wedge basically..
top and bottom wear out
bottom pushing against the moveable sheave and the top pushing against the retaining bell;
the latter providing the angular offset that brings the moveable sheave closer to the fixed one (narrowing the sheave distance, forcing the belt into a larger effective diameter.)
the weights do NOT act as the shoes in a cent clutch would.
they do not provide any rotational resistance.. in fact they work best when nicely lubed (drylube!) they do not rotate respective to any of it's contact surfaces neither the sheave nor the bell.
All they do is wedge the two apart.
lack of lubrication and grime/dirt/etc cause them to wear and since the -let's call it clamping force- of the sheave and bell is MUCH bigger than the fixed-sized drilled hole where the rods run in (which ideally is zero ;))...
the contacting surfaces wear much quicker than the rods would of course.
if the lands are worn down to the mark completely..
the garter springs and overall shape of the bell would likely prevent the sheaves from closing all the way down on the belt and you'd loose at least the overdrive capacity of the Tav2.
keep in mind that spring tension and resistance is non-linear and the available space is restricted as well,
you'd lost material (thus weight.. and as a result expanding force.....) so the TC would act much slower than before... also the additional surface only adds to the resistance, which again is counteracting the expansion.
more lube perhaps ;)
Anyways.. no... replace the weights if there's no detectable step on the outer edges.
in theory if you can rebuild the lands, nothing would stop you from reusing the weights then,
but the angle must be perfect in regards to the bell, the weights of the two halves must be absolutely identical and any build up material must be softer than the steel of the bell and
must be fused with what's left of the weights in order to not split back up under load...
all in all.. melting and recasting all of the weight would be a better idea IMHO than to rebuild the surface
Anyways it should be possible, if it's worth the hassle I can't tell ;)
Bbqjoe
Banned
Location, Location
Thank you for a very detailed and clear explanation. This helps me a lot!
:thumbsup:
:thumbsup:
Kentucky Boy
Bowling Green, KY
Mine wore out and then my spring got stretched out real bad. I'm pretty sure the weight wear caused the spring damage eventually. Replaced the whole thing. As far as the talk of melting them and recasting...brand new one costs about $20. They are not made of lead so I think you would have a hard time melting them.
Bbqjoe
Banned
Location, Location
Thanks.
I just try to get the most out of things before they go into the "What'll it be next?" pile.
The lands on my current weights are just about gone, and I have a new driver ready to install, so if I kill this one through experimentation, it's really no big deal.
Here's my latest idea.
I have some 1/8th inch aluminum sheet.
I also have a really decent epoxy putty.
I could drill a bunch of holes into the current lands, cut the aluminum to shape, and score up the backside.
Then epoxy the aluminum in place and file to shape replicating the new ones.
What do you think?
Rail rider
Inmate # 3192016
Planet earth ( the flat one)
Thanks.
What do you think?
If its already wore out.
I'd experiment with a welder and reinstall the lands on both sides ... See if you can milk out another 100 or so miles. If the welder doesn't work then try the epoxy trick.
Bbqjoe
Banned
Location, Location
All except welding wire is probably a lot harder metal than the weights?
No sense in killing the cover if we don't have to.
IIRC the original weights are zinc...
zinc brazing rod perhaps???
sounds more plausible to me at least ;)
