Predator 8hp
Get a 40 series. You'll be glad you did. More bottom end torque and an overdrive at the top. And with that 301 with a little help on the governor will put a smile on your face.
Do it
The Army lol we say hoah....just a play on words
Sent from my SAMSUNG-SM-G930A using Tapatalk
I thought Army was Hooah and Marines was Ooh Rah?
---------- Post added at 07:22 PM ---------- Previous post was at 07:21 PM ----------
And here I am with Oofdah
Gears
Lol its hoah or hooah either way or hoooooooaaaaahhhhhhhhh if your having a good day or being a smart *** as long as the letters are in the same order you can't be wrong lol
I had a feeling Army.
I just asked so I could Say...
Thank you For your service!:thumbsup:
Lots of Army guys here, once in a while a Marine too.
Gears
Thank you for your support :) just picked up a new gocart frame wife's gunna make me sell my old build :-(
Gears
The motor is HERE!!! But I'm running into the issue you described the oil cap is in the way I removed the oil cap to see if it would clear and it still won't maybe I have it set on there wrong could you post a picture of how you have yours? It'd save me alot of time20170121_073643.jpg
You can use the backing plate but you have to do something about the rear dipstick. It gets in the way. I had to grind it down and seal it with JB weld. I did this before I put any oil in it. Worked out fine and is still working fine.
Gears
Did you get the engine yet? That ebay seller looks to have several 8hp for around that price. Free shipping. But he has no sells on his name yet. Meaning new ebayer. If you get yours i may buy one. Almost worth the chance to try and see what happens.
---------- Post added at 03:26 PM ---------- Previous post was at 03:17 PM ----------
Man this guy has them for 85 buy it now 10 left
http://m.ebay.com/itm/8-HP-301cc-OHV-Horizontal-Shaft-Gas-Engine-EPA-New-100-/182419521150
Tempted.......what will i build next? Upgrade my kart maybe.....
It's came early and it's brand spanking new I got mine for $74 but they can be had on buy it now for $80 ebay predator motors are legit and a go at this station!!
qtband
St. Louis, MO
Here's what you can do....
Buy this stage 1 performance kit.
http://www.gopowersports.com/predator-301-420-performance-kit/
Then remove the crank side cover and remove the governor and its components.
Remove the dipstick and grind off the threads on the cover that hold it in. It's scary, but it'll work fine.
Thoroughly clean the inside opening of the dipstick hole (made easier since there was no oil in it yet...).
Use something to block the hole so you can fill it from the outside with JB Weld. I used a piece of rubber I cut to fit. Paper towel or anything else will work.
After it is cured, put the cover back on. The TC will now fit and you have your governor removed.
I did this a few months ago and everything is still working great.
By the way, install the jet and make your header before you start it for the first time. No gas, no mess!
EDIT: The pictures loaded upside down....
