Need to know what brake fluid to use and need to bleed it..
nghianevo
Chandler Arizona
My Kart been seating out for around 8 months and neglected and now i decided to make it run again...last night i found out tat my brake is no longer work....what gift..i think it just need to bleed the brake..but in order for me to bleed it...what do i need to do ...and can i use regular car DOT 3 DOT 4 brake fluid ? or it need it it own brake special fluid..
Rail rider
Inmate # 3192016
Planet earth ( the flat one)
Dot 3 probably, it should say on the master cylinders cap ,go buy a vacuum brake bleeder..You'll love it.but if it's been sitting you may need new plungers for it. Does it hold pressure or leak down?.Don't forget to hone it if you replace the plungers. Get a small container and a hose put the hose in the container pump the peddle to drain fluid after 3or4 pumps refill the master. Keep doing that with the hose in the brake fluid to not allow air in the slave cylinder.. keep going until the fluid comes out clear.
nghianevo
Chandler Arizona
i have no idea what is that plungers.. and yea.. i cant really tell what is it.. but where is the master cylinder.. the one near the front or the one near the rear next to the brake disc....and can u send me a step by step....
How about you post pics of what your brakes look like... Then we can tell you what you have and what everything is...
nghianevo
Chandler Arizona
this is my brake.....
nghianevo
Chandler Arizona
it european brake... and isnt european brake run dot 3 ?
---------- Post added at 01:48 AM ---------- Previous post was at 01:47 AM ----------
and if it run dot 5 ..crap
.i just fill in the master cylinder with dot 3... ..
btw...i put the dot 3 fluid in and wow..it have alot of air... like a lot of it
---------- Post added at 01:52 AM ---------- Previous post was at 01:48 AM ----------
the kart is all kart chassis abd seems like build by all kart ..and the brake master cylinder is european brake
andrecht
Jup, picture = me
Germiston, South Africa
Dot3 is fine....Dot4 &5 have higher temp ratings for more modern ABS type automotive applications...
nghianevo
Chandler Arizona
ok wheww. that was closed... but now...i filled the master cylinder up with dot 3 brake fluid..abd i pumped the pedal...it have alot of air inside the line... and the fluid go slowly into the both brake calipers...nowhow do i bleed tbe air put
Flyinhillbilly
The great cornholio
North West Arkansas
There should be bleeder screws on the caliper. I'd make double sure I flushed the whole brake system really well as DOT5 brake fluid don't mix with any other. Can't hurt since you didn't know what was in there and some guys (me included) like to use DOT5 since it's hydrophobic, and has a much better temperature rating.
Rail rider
Inmate # 3192016
Bro, your disc is missing a chunk.you need a new disc.the bleeder is that rusted part above the tubing in last pic. Don't run it or you will need to replace the disc ,pads and slave cylinder. This is another reason to post pics.
nghianevo
Chandler Arizona
can u see my picture and tell me where is the bleeder screws ? .and last night i put some of the brake fluid in the master cylinder..and it seems like the brake fluid came out very dirty...seems like it contaminated so i will flush the whole thing...now that mean just keep pumping the pedal and insert the brake fluid over in the matlster cylinder and until all of it came out ? ..
---------- Post added at 12:11 PM ---------- Previous post was at 12:09 PM ----------
hey rail rider..really appriciated u for answering and yes..i inspected..and saw it missing a chunk...and i am already orderef a new disc.....now..the bleeder screw is the hex nut that just above the tube thing rught ?... so how do i flush the whole thing...and how do i know which disc to get
Rail rider
Inmate # 3192016
That is the fun part take the old one off and find the numbers and makers mark. I've only had single disc this thing is a vented rotor. Once apart post a few pics in a new thread... And wait for itsid... He seems to know everything..
nghianevo
Chandler Arizona
lol....dang... ok...i gotta take everything apart crap.....
---------- Post added at 12:38 PM ---------- Previous post was at 12:37 PM ----------
lesson learned....dont ever let ur kart seat for untimely event of period....more money getting it to fix then having fun with jt..
