wax is tricky, mostly because it's too soft to be properly pulled by the extruder;
the actual printing isn't much of an issue really ..
but there's no real reason; molten aluminium removes std ABS just fine (natural white works best since it leaves no dye of course)
Anywhoo, that looks nice indeed.. and I'm not concerned too much either about it withstanding the compression (depending on your infill that is.. but I think upwards of 30% should do with 3walls and a part of that size... and judging by the pic that's a solid part, right?)
it's the rotation that makes me worry..
as soon as it catches (say a small grain of sand catches both the bearing seal plate and the spacer...)
it'll be worn out in a matter of hours.
or at least down to a point where it doesn't hold up to the compression really.
I like that gun-metal color...
ever tried acetone vapor polish on that? should look great.
Side note: your x-axis could use a slight drop of oil.. it looks like it catches at times
