will this brake work with a 13hp engine
Rob711
Long Island, N.Y.
40$! Did u read the answered questions, does in need additional fluid resovoir? A guy says it worked on a tractor.
Pls get it and show us what your putting it on, wondering how it compares to the mechanical caliper set up for 70$
It should be fine, go for it; I have a similar setup on my kart & I barely need to touch the pedal...
Without having compared the two, I would say much better; T-Man did a vid on a similar setup...
x-Speedy-212-x
●▬▬▬▬▬๑&
Not The Slow Lane.
I am considering this brake system and have questions:
Could it supply enough force to lock the axle at 30mph?
How about good braking at double that?
I'm guessing a hydraulic reservoir is needed along with it but I don't know what kind it is .
I did submit a question on Amazon about the product and someone responded it barely slowed him from 40. Maybe no hydraulic fluid was used?
I don't know. You seem like you would know , what is your experience?
Thanks and much appreciated.
First, this is what we call hijacking; even if you have an identical question to one already asked,
PLEASE START YOUR OWN THREAD...
I have an almost identical setup on my kart &, yes, it locks up at 30mph, it all depends how hard you press the pedal; granted, my kart is small & light but, I see no issue if the kart is slightly larger; I wouldn't go putting that setup on a large, overpowered kart...
As for the fluid reservoir, it's built into the master...
A few things look Familiar here....
Is that you Freerunner15?
Why the new account? you can apply for a name change to match your youtube. :backtotopic:
Most of us want to go faster and you want to slow down.. Hmm
Seriously. I even drive that way, and plan well in advance to avoid hard braking.
I also time my stop n' go traffic driving to get all the green lights. Stopping is NOT GOOD.
:backtotopic:
