HF Tig
sen2two
up and coming...
Orlando, FL
the HF TIG welder can be "OK" at best. the main problem is no adjustability. with most TIG welders you can press down on the pedal or relaes to get more or less amperage. witht eh HF one, when you start it, its ON. plus its very low powered, and if something breaks. your screwed. i almost bought the HF one until i did my research.
i wounnd up getting a Lincoln 175 sqaure wave. AC/DC, this thing does it all.
zero1dhd
Master Fabricator
Lake Elsinore
Normal progression of welding techniques
ARC - cheap easy and ugly. You can pretty much just drag the electrode and get a strong enough weld. Minimal skill required.
MIG - can be cheap, relatively easy, but requires a little skill to get a quality bead. Practice makes perfect...
TIG - if you cannot MIG like a champ, I wouldn't even try this one. It is an entirely different technique than the other two. If you watch TV shows with guys TIG welding and say that looks cool I wanna learn how, realize those guys have been TIG welding for years if not decades, it is nowhere near as easy as they make it look. You need to have good foot control, hand control, and really good hand-eye-foot coordination. As you weld, the metal will tell you when it is time to dab the rod. I could go on for days about TIG techniques, but I won't unless asked...
And then there is
BRAZING - which I don't consider welding at all, but it can be strong. I would say it's somewhere between ARC and MIG as far as skill set. All you need is rosin (aka flux), brazing rod, and a torch. Apply the appropriate flux to area of desired "weld" heat from opposite side and apply appropriate rod (opposite side of heat source so the rod flows to the heat just like soldering) and let cool.
sen2two
up and coming...
Orlando, FL
dont forget oxy acetaline welding also...
like brazing, but you actually weld. brazing is more of a bonding. with welding, the metals melt into eachother.
oxy acetaline is VERY easy and can look almost as nice as TIG if done right. alls you need is a torch and some wire hanger...
fluxcored
i weld for a living and trust me,the Miller is one of the best rigs out there.
I've been out of the game for so long but yeah - Miller's good quality kit to have.
I refuse to get rid of my MIG just because it's a Miller altho I have'nt used it in over 4 years now.
modelengineer
Lord of the noise
Sydney, Australia
Ahh.......? I'd say arc is MUCH more difficult than MIG welding. MIG is like a glue gun compared to arc welding, much more difficult to get a clean bead with arc. MIG welding is just getting the settings right and off you go.
(and before you ask, yes I've tried both)
Kaptain Krunch
Pro Junk Collector
vermont
agreed, and flux core is the most "glue gun" like, and easiest welding process, then mig (gas isnt that hard to set but its just one extra step) . I picked up the welder and was laying down decent beads within 10 minutes, and it only took me that long because my dad had the wire speed at its lowest and said it should be any higher than that.
Khyren
I personally have the XMT 304 CC/CV Miller unit but lack the TIG torch for it. Anyone know a good place to buy one at a decent price? I have the MIG feed unit that we had for it at work with it. There was a TIG torch for it but it grew legs and walked out of the shop one day.
Khyren
lemegacool
got boost? :)
quebec canada
Khyren
yeah xmt304 ROCKS!!! tough as hell! and performs really well with all process! and check ebay for a torch...
Khyren
It is 10 years old and still works great. I got it with a s22a feed unit, 44lb spool of wire, and a 15 foot m-25 lead for just under a grand from the :going out of business" sale at work. Anyone interested in a Millermatic 251? Got one of those too.
Khyren
fluxcored
Khyren
If I was close by I would have taken you up on that offer!!
lemegacool
got boost? :)
quebec canada
Khyren
d'ahh it's the semi auto welder i would like to have at home... well me too i'm not close...
Scout
Nutjob
Indiana
Oxy-fuel is just like tig, just a different heat source.
If you have an ac/dc stick welder you can add a tig torch and bottle and get a cheap tig. I've got $600 in mine and that's buying local, I bet if you watch for deals on ebay you can set one up for half price.
rgvkid
Charlie Don't Surf!
Los Angeles, Anaheim
Another problem with the HF, isnt it 220 only? I need a portable 110 Tig to take with me for onsite installations for my work. I make custom iron work and Mig is just to worrysome when im working in doors over High end Hardwood floors or tile. What would you suggest for a portable 110 tig.
