Stretched Big Block Streaker
rockman96
SC
A couple years ago I posted some pics of this build in it's initial configuration. I have since done a lot of mods in the engine area, so thought I would post some newer (and a few old) pics to show what it loos like now. And, I am getting ready to do some major mods to the engine and induction system... If these work out, I will be posting more pics over the next several months.
First, some frame mod pics. 7" of stretch in the wheelbase and controls:
Frame / Axle / Engine mount strengthening for 420:
---------- Post added at 05:39 PM ---------- Previous post was at 05:29 PM ----------
Skipping to the finished kart:
Unrelated welding table build. Woohoo!
Nice work. Well built. That looks like fun.
How does it perform? Handling and Top speed wise.
rockman96
SC
Thanks. Nimble, runs straight, 52mph with 260lbs of me on it, with current gearing.You should see some dramatic changes in the power section soon. If it all works out. :D
MrC.
florida
Looks Great, those frames are very strong to begin with.
How about some action shots like; burn-outs, wheelies, jumps or even a good drift!
I'm glad I am not the only one that think these need more gear. Nice jack shaft build.
MrC.
I like the tires--never seen the tread pattern before in that tire style (tall, narrow). They look like a good all-season tire.
Anyone know what brand they are?
rockman96
SC
Thanks guys.
Those tires/wheels are from Northern Tools. ETA: I have another set of fronts from NT that are only 2/3 the width of the ones pictured, but I like the way the wider set feels.
---------- Post added at 09:59 AM ---------- Previous post was at 09:40 AM ----------
Anyone played around with blowers at all? I've had other things come up recently that took away my momentum... Hopefully I can get back to it soon.
I plan to use an S&S Super B carb with this, and build a large plenum between the blower and the engine. These are from the Japanese market, they came off Subarus, etc.. Check it out, quarter on case for size ref:
[/IMG]
Flyinhillbilly
The great cornholio
North West Arkansas
Messed with a few blowers, mostly turbos and nitrous. That's an AMR? Get your pulley speed right to set the boost, and pull timing. I like to start at pulling 1.5 degrees per pound of boost and increase it 1 degree at a time until it stops picking up mph (drag cars on drag strips) you probably need a dyno to really nail it down, but 1.5 degrees per pound is usually a safe place to start on cars and bikes.
Where do you think you want to put the pulley that drives the blower?
If driven off a shaft after the Torque Converter (like TC jackshaft or axle) the boost will be lower when in low gear and higher when it upshifts. I was afraid that might cause issues, but have no experience. It might work out better that way???
lots of interest in this. I hope you go forward with this so I can copy.
rockman96
SC
Yeah... Aisin/AMR500.
What CR do you shoot for typically? This engine is 8.2:1 now, but I will be putting in a stronger piston than stock, which is supposed to yield somewhere in the 9:1 range... I figure I'll probably have to mill the top of the piston a bit, or open up the comb. chamber to drop it down to 7.5:1 or so.
The blower will not be driven from the TC. It will be driven off of the right side of the engine.
The AMR 500 will be too big! Moves 500 cc's of air per revolution. You need the 300, it will be more efficient. :thumbsup:
rockman96
SC
It will not be too big. The stock engine is 420cc, and the output is adjustable via pulleys.
:thumbsup:
I love the way the gas tank looks.
:popcorn:
---------- Post added at 03:34 AM ---------- Previous post was at 03:33 AM ----------
The 500 is always cheaper on ebay too. The 300 must be more rare?
