True if the piston moves up the cylinder. Could just buy a piston that increases the compression, don't need the rod to do it. I figure a longer rod is good as long as the piston pin doesn't interfere with the rings. I look forward to building up my long rod 400 Ford but with a long rod from the factory compared to other sbf engines it had the lowest compression of them. The cc of the engine ultimately decides the compression.
Sort of....the swept volume vs the compressed volume does....( provided you have good rings and seated valves...lol).
But as you said...IF you move the piston closer to the head ....you will increase compression....reguardless....(but relative to original compression and the only change).
You could actually put in a longer rod...and change cam timing and LOSE compression...but that's a whole other can of worms.
But...as I said...rod length outside of any other changes will add some torque...but the change will be minimal....it will reduce the side load on the piston skirt....how much and to what benefit...IDK....especially without changing anything else....can't see much difference in that with a .020" or whatever longer rod....
Now...stroke...that's a whole nother animal....a little goes a long way because the increase is in the swept volume and doubled....because the piston moves more in both directions.
And long rod engines are traditionally torque engines while short rod engines are high rev. (Of course ...usually stroke and rod length go hand in hand.)
Sooo...for example..those formula one cars have only like a 1 1/2" stroke and turn like 10,000 rpms.
