The 94C was meant for snowmobiles (im thinking 2 stroke high rpm?). But it can be adjusted for a lower engagement RPM.
Did you replace original pucks? The heavier the pucks, the lower the rpm engagement will be, and the more outward force to make the drive unit engage and overcome the driven units spring tension.
http://www.vintagesnow.com/Clutch_files/comet 102C and 94C.pdf
part number 206515A for pucks would be the ones that are the heaviest for lowest rpm engagement, pulled this from the manual and it shows the slightly lighter pucks used for 4 strokes (briggs/tecumseh etc)
DRIVE UNIT should have something like this?
206095A 94C
pucks #206514A
pink spring #205858A.
1 3/16" width belt
The manual refers to the "
94C Calibration Guide http://www.geminikarts.co.uk/files/comet-94cdustercalibrationguide.pdf" might want to do some digging for that. Another page about tuning it:
http://kawicat.tripod.com/weblog/id4.html
couldnt find tuning guide, but here is a website that sells it WITH THE TUNING GUIDE so you could ask the owner of the site to maybe scan it and send it to you
https://www.denniskirk.com/comet/94...tch-with-6-pucks-212629a.p38185.prd/38185.sku
Also could be driven units spring tension, and/or center to center distance.
If the problem is the engine (which i dont think it is unless u messwed with it) see if you can rev it to 3600 rpms under no load, then put the belt back on, and put the go kart on blocks and see if it fully engages then. If it fully engages then, you know its not the belt. It could be a belt that is too large for the center to center?
So
puck weight problem?
belt width/diameter problem?
driven unit spring tension problem?
Could be other stuff, but id look into that first
