It won't clear them. Disconnect the battery for a while to do that. I think.
I agree with this guy. Changing those always makes me want to rinse my mouth out with a pistol.Yup. The dreaded 0320. Most likely the crank sensor.
First rule out bad wiring check powers and grounds.
It's a pain to reach. If you can pull back the carpet on passenger side "some models" have an access panel that lets you see the sensor but I'm not what year they started putting that hole there. Other wise from the bottom with a 3 foot extension you can remove the little retainer screw in the sensor. Then from up top reach down and use your third elbow, stand upside down and hold your tongue just right, and remove sensor.
I made a lasso out of some twine to help fish the wire back up when I undid the connector.
Nothing hard, just a real tight fit if you have big arms...
dude.... skinny arms dont help on that darn part.....
I ended up getting a wobble extension set to make about 30" long to reach the bolts....
This after spending 1.5 hours scratching the crap out of my hands and arms.....
That so far (if it was true) makes the most sense to me.check the seats!!!! Auto kill switch if not heavy enough! I see it all the time on lawn mowersoh wait this is a jeep? never mind.
Have you tried asking members on a jeep forum? In my experience, members on any forum have the most experience and can usually give you an answer that's correct.
I'm a Jeep forum member I see ml toys is a forum member also.
I work on a lot of Jeeps.
I guess I'm with ml toys
