Trick question*
Bbqjoe
Banned
Location, Location
Ok now.
You work at a motorcycle/ ATV place that does tires.
Someone hands you a tire and a rim, and says this tire needs a tube.
First and foremost, What's the first thing you do?
(Let's just assume you possess the tube and the tools needed.)
*This for for two Chicken dinners at St. Alfonzo's Pancake breakfast.
Remove the valve stem an take the tire off the rim!
I like the Chicken and Waffles at Alfonso's
Staff Murderator
You blow up the tube first and make sure there's no leaks.
First thing I would do is check the tire for any thorns or nails still sticking through that will puncture the new tube
Joe-405
Enjoying New Projects
U.S.A.
Seems how I know this is a trick question cause I was a manager at Cycle gear...............
Get the customers information to call them back.
You could also make sure the wheel is straight
You could also make sure the spokes are tight
You could also makes sure the wheel has the rubber band spoke protector on it.
You could also check to see if you have the correct tube in stock
Bbqjoe
Banned
Location, Location
Ok, Ok, ok...............
How about checking what caused the flat in the first place???
The jack@ss put the tube in with thorns still in the tire. Flat tube the next morning.:censored:
Staff Murderator
I assumed it was a new tire and new tube. Since the condition of both items wasn't mentioned at first it kind of makes this whole "trick question" shenanigan just a mindless waste of time. Oooh, you changed the parameters of the question at the end. The tire was punctured! You really tricked us. I hope I can be clever enough next time.
Furthermore, it's not even remotely fair that the OP and Chancer already had a previous discussion about this very topic on another discussion venue. So Chancer already knew the answer. And answered it. Whoo, big challenge. Pat yourself on the back Chancer. Good boy!
That's cheating even if it's written in 'invisible' ink.
Bbqjoe
Banned
Location, Location
I'm sorry Mr Hellion for not elaborating that this was originally a tubeless tire. To me it seemed obvious that it went flat, so needed a tube. I will be more careful in my descriptions in the future.
Please note, Chance did not win the chicken dinner.:p
