15 HP Engine, what is a good gear ratio? Thanks
aham2003
Cleveland, Tn
Yep, get the jackshaft positioned about where you want it,
then measure where you are at in relationship to the engine.
Make fine adjustments until the distance is one of the ones in the chart.
Make sure the pulley fits.
Make sure the sprocket fits.
If you must go in between two sizes, get the bigger belt.
Search for replacement belts in that size just to make sure.
---------- Post added at 03:11 PM ---------- Previous post was at 03:10 PM ----------
What do you know about crazy? :roflol:
We have lots of Go Power Sports Reps here!
Want to know how to get 10 Percent off your next purchase?
I'll tell ya for 8 percent.
---------- Post added at 03:16 PM ---------- Previous post was at 03:11 PM ----------
There may be a discounted one for sale that needs a DriveR and Belt.
http://www.diygokarts.com/vb/showthread.php?t=34238
Just used the 10% discount for a $240 dollar order last week!!
Joe-405
Enjoying New Projects
U.S.A.
Are you a GPS rep? LOL. It would be crazy to buy that thing. You can get a jack shaft kit, 40 series pulleys, and belts for about $175. If im not mistaking, they want $400 for that kit. So they want $275 bucks for a $30 belt and $30 piece of steel.
Actually I am cause I have a used one in the for sale section. :lolgoku:
aham2003
Cleveland, Tn
aham2003
Cleveland, Tn
thunderstorm
Thanks everyone, but how do i know how reasonably loose the torque converter belt is suppose to be?
you measure the distance and buy the correct belt for said distance... easy huh ;)
vice versa.. say you have a belt; then adjust the distance to match it's specs.
also not too difficult, is it?
