new owner of a dingo
Garryjav
joppa md
Hi all I'm Garry in joppa md. I have been playing with go karts for a few years now, the grand kids have a ball in them (so do i)
have a 6 hp dead axle manco and a little baja motorsports dn165 with a live axle and a pred 212cc
some of the grand kids are big enough to drive the manco now so i picked up this old dingo for myself
it needs a bit of work main thing it the right side hub must have lost the key and some jackass welded it on. so it needs a new axle and hub. does anybody know how wide the axle is? and i assume it uses a stepped hub ?
My dingo has a solid 1" axle and it's only stepped down at the threads. The hub bottoms out on the axle. There is a spacer sleeve between the hub and bearing.
Post pics so we can see your set up.
And welcome to the forum
Garryjav
joppa md
Here's some pic's of it. it looks like they welded the hub to the spacer
and the nut is tacked on too. the hub will move about 45 deg. on the axle so i'm thinking i'm going to need a new axle and hub
Probably best....as much as I like GoPowersports....BMI has some really good axle prices....but shop both....and include shipping...and the 10% discount for DIY members at GPS...just to be sure.
Garryjav
joppa md
well then has anyone replaced the axle in a dingo ad knows the specs on it? i would like to get all the parts and just work on it once
You could try to save the axle by carefully cutting around the weld...
Wait, what do you mean by
Do you mean the hub rotates on the axle? That would indicate the weld didn't hold; IIWM I'd cut off the tack & see if the hub can be removed from the axle...
Garryjav
joppa md
i had some time so i took it apart, turns out the axle is scrap and 36 inches long not counting the threaded ends
also pulled the engine off,check out the weld or lack of on the jack shaft
took some pics of the little baja cart and the manco too
