Almost removed governor need advice.
Jfive
Great falls Montana
Removed the arm, and the plastic gear except this much. Think it's okay or should I continue to fight that **** snap ring.
If it were me....
I'd take the flywheel off and punch out the whole shaft from that side.
Plug up the hole with a bolt.
I had a similar result and ended up doing ^
---------- Post added at 04:19 PM ---------- Previous post was at 04:08 PM ----------
What engine is it?
Jfive
Great falls Montana
The YouTube video don't show it that way. I wasted so much time I would of took the other side off if I had known about it. I took the bolt and nut from the gas tank to plug the governor shift hole and some high tack.
I fought with that wire clip, Hammer and Screw driver.
But it is all gone now.
I thought those rod cap bolts had 12 point bolt heads(on the typical stock clone and such)..... all the new aftermarket ones do?
Interesting vid... I think he's local to me.... at least Canadian......
He's working on a princess motor...
IMO, it should be fine as it is, nothing is in contact with the engine internals so, nothing should be damaged; in most cases, it's the pieces of the exploded governor gear which causes the damage...
Flyinhillbilly
The great cornholio
North West Arkansas
I put the edge of a flathead screwdriver against the clip and hit the screwdriver with a hammer to deform the clip. They pretty much fall off once you get the clip screwed up enough.
X2 on it being fine as is.
