Yeah...those Briggs carb diaphrams are CHEAP. I almost always replace them anytime I crack one open.
EEAASSSEEEY! This is family friendly forum....I see the plain brown box....![]()
Hey Briggs Brother--thanks for showing the closeups of the con rod and all the speed parts, the good photos, and all. They speak thousands of words and you're one of the few who 'gets it' about posting photos. For the rest of the DIY denizens, it's like pulling teeth so much so that you'd think we were living in the pre-digital era of point-and-shoot and 35mm SLR cameras that use FILM. It's like asking them to have their film developed, prints made and scanned for the forum.
That con rod dipper detail is intriguing. I didn't know it was spoon-shaped at all.
Anyway, the point is that the OEM springs are 2 different sizes (1 tall, 1 short). And the upgraded springs are the same size (both tall). Does this matter? Can I run equal size/weight springs on both valves? Any help with this conundrum would be greatly appreciated fellas. Thanks in advance.
Just use your bionic hand to squeeze it down.
I am aware of the different part numbers for the two valves and the slightly different sizes--I have no information on why this is though.
I can tell you it is the exhaust spring that is the taller of the two. At the same time they don't appear radically different from the photo at Dynocams. I will say that their springs appear to have one more coil or "rib" than the OEM Briggs (those differentiated from the coils that form the extreme top and bottom of the spring). So yeah, they appear to be stiffer.
I say go with what the aftermarket (in this case Dynocams) tells you to do.
