Cam for Built Hemi
Kentucky Boy
Bowling Green, KY
I'm wanting to get a new cam for my hemi. I'm looking for one that will give good performance and idle good. I have a Predator Hemi with no governor, billet rod and flywheel with 8 degree timing advance built in. I also have a big intake with a 22mm Mikuni carb. Has a header also. What would be a good cam for performance, good idle, needs 32 degree btdc timing? Also what springs would pair up with it? Thank you.
How many RPMs are you looking for????
Since you are looking for good idle, I assume you don't mean a 4000 RPM idle right?
I like the Black Mamba Jr because It works with my desired RPM range.
I wanted to keep the RPMs below 7000 to be safe with the stock flywheel.
It is considered a "Torquey" Cam.
Should be good to about 6500 RPMs depending on gearing, tire size, weight, .....
Pulls hard the whole RPM range.
I have the gx390 carb and a 30 series TC with stock springs.
It pulls hard from 2100 to 3100 RPM, then really gets going.
This might be the cam / carb or the TC shifting or a combo of both.
NRRacing or DynoCams are good places to look.
NR gives better descriptions.
They will tell you 6000+ or 8000 - 9000 RPM.
They will say for long tracks or short tracks.
They will say for 12:1 or greater CR or for 9:1 or less CR.
Most will want 32 degrees so you are good.
They will specify what springs will apply the appropriate pressure for the cam lobe shape.
For a yard kart, I'd look for something that says WIDE POWER Band. or WIDE Torque Curve.
---------- Post added at 10:15 PM ---------- Previous post was at 10:11 PM ----------
http://www.nrracing.com/category-s/2225.htm
---------- Post added at 10:28 PM ---------- Previous post was at 10:15 PM ----------
So a quick basic intro into Cams for small engines.
More lift = more power at any RPM
More Duration > shifts the Powerband towards higher RPMs
So a High Lift, short Duration cam might be a Low RPM, Torque Cam.
A Long Duration Cam may make it difficult to idle and run poorly until you get into the PowerBand of the Camshaft.
Kentucky Boy
Bowling Green, KY
So I spoke with the guys at ARC yesterday. They were very helpful and courteous. I now have a Mod 2 Cheater cam and 22 lb springs on the way. They said this cam will give very nice gains and the motor will still idle good.
Grape Ape
Virginia
I know some guys running that cam, against recommendations they went to 18 pound springs due to loosing too much low end torque (their words not mine), I just built mine up (bought with damaged crank) and its has the Black Mamba, have not finished kart yet so don't know how its going to do but idles fine at 2000 rpm's.
CoroTheCat
Builder
Denmark
I was looking at cams a bit but couldn't find the "values" for the stock cam. Does anyone know the stock lift and duration, because I find it a bit hard to choose a cam when you can't even compare with the specs of the original one. :)
If Bob does not answer you.
Call ARC. I am sure they know, and it sounds like they are very helpful.
Not positive, but it should be around 215 degree duration and 0.225" lift IIRC
Cheater cams usually have stock lift or stock duration, while the other is changed I believe.
So maybe lift is like 0.22" and 0.23" on the stock cam. I still think stock duration is like 215 degrees (it is less than 230 degrees)
My Black Mamba Jr has a duration of 230 degrees and lift of 0.275".
It is a 6000+ cam, but pulls good from 2000 - 6500. It idles perfectly.
I post a spreadsheet some where with specs and RPM ranges for different cams.
Let me see if I can find that post.
I'm sure I had something more complete, but I can't find it.
CoroTheCat
Builder
Denmark
i tried messaging ARC and the said i should contact Dyno Cams, so now i'm waiting for a reply from them :)
Kentucky Boy
Bowling Green, KY
I installed the Dyno cam mod 2 cheater cam that I ordered from ARC. It has clearance issues with the crank shaft.
The exhaust lobe just barely hits the crankshaft. Anybody else had this problem with the mod 2 from Dynocam in the Predator Hemi?
Grape Ape
Virginia
Yes, not myself but others within my group. A little grinding on crank to make clearance will fix the issue. Note: make sure you disassemble the connecting rod and remove crank to do grinding. You do not want to get any grind dust in your bearings. Will eat the engine up in just a few minutes, seen it first hand.
Kentucky Boy
Bowling Green, KY
Is it better to grind the cam or the crank? I would think grinding the crank would not be good since it's balanced and is a larger rotational mass. I don't think it would require very much material to be removed.
I called the guys at ARC and they said grind some clearance off of the crank. Need clearance of about .005 between the crank and the intake lobe of the cam.
youngDUMP
North/South Mississippi
My experience has been with the CL2 mod 2 and the black mamba jr.
The CL was awesome. Loved the top end. Really came alive at about 4K and pulled to 8k strong with stock jetted carb.
The black mamba jr is what's in my bike now. I prefer this as I do a lot of drag racing. We race 330' (1/16 mile) and the mamba jr tears out strong and pulls to 7500 on stock carb.
I just got my 24mm flat slide Mikuni in and I need to install it. I believe the carb is my limiting factor as it starts cutting out when I hit the top of my rpms with the mamba jr at 7500. Like it's got a Rev limiter. Hoping for more rpm with the bigger carb.
BTW my mods are
+.020 rod
Billet flywheel
32 degrees timing
Air Filter
Jetted carb
Open exhaust
Good luck. Hope this helps
BTW my mods are
+.020 rod
Billet flywheel
32 degrees timing
Air Filter
Jetted carb
Open exhaust
At some point the Jr camshaft has to limit your RPMs, right?
The same cam can't pull forever. Let me Know if you get more Rpms with a bigger carb. I thought 7500 was pretty good with the Black Mamba Jr.
