Rear wheels
Berton
I hope this is the correct category! So I am in the process of buying parts and building my go kart. I have a rear axle that's 1" with a step to 3/4 at each end. The question or problem I'm having is finding a wheel that is one piece That has the step for the axle. am I going to have to get a 2 piece because of the step on the axle? I already have 10/4.5R5 on the front so I wanted the same or slightly bigger if possible! Hopefully you guys can help!
KartFab
Uhhhhhh lets back up here
1) the step means you can put a hub on it like this. That's what manco did with these axles in the past. http://www.ebay.com/itm/4-x-4-Wheel...316656?hash=item2108e799b0:g:vdcAAOSwL7VWoPrN
2) you can also put just a straight through 1" bore hub on an axle like that, and from the looks of it (since you said you are having trouble finding the right rims that are 1 piece) you already have found the solution to this, but its a 2 piece.... why do you want it to be one piece? There is nothing wrong with these two piece rims, you just put the tires on them with a tube in the tire. Problem solved. To secure the rim to the axle you can just use 1" lock collar on one side of the rim and a 3/4" nut and washers on the stepped end.
DeathMachine
Eastpointe MI
No...they make 3/4" / 1" wheels and hubs. Once again...a pic would be extremely helpful.
I was basing my opinion on this, if those wheels are stepped then I apologize for any confusion.
As you can see from what you posted...there is definitely not enough 3/4 portion to hold a wheel and use the 1" as a stop. That is exactly as Grant described it with 1" hubs and lock collars.
As always..a pic would go a long way in avoiding confusion.
Berton
This is the only way I could find a way to post a picture hope it works
44" with 2" of step from mfg supply
kenworth85
Grouchy old man
Blanchard Oklahoma
1" bore wheels will work. Add piece of conduit on the 1" short enough to get a flat washer and lock nut on the end of the axle.just a suggestion
