First Post - Predator 212cc won't start!
rman
Hey all - First post here! Too bad it's a help me post!
Anyhow, put a Predator 212 in my doodlebug last saturday, clocked it at 37 max before bouncing off the governor.
.038 Jet, emulsion tube and pilot jet.
air cleaner
straight pipe header
So today, I rip it open and take the governor out. Cam and gear fall out so I line them up before reinstallation.
Link the throttle arm up to the butterfly, fill it with oil, mount it back on the bike - and nothing.
It doesn't even sound like it's turning over. It just sounds like the recoil starter really. Shaft and clutch are spinning, so I know the crank is spinning.
Pulled the plug and it is dry. Have not opened up the valve cover yet.
What could cause this? I disconnected my kill switch and reconnected the stock kill switch, disconnected they yellow oil sensor wire. So I don't think it's electrical.
Does the piston need to be in a certain orientation when lining up the crank and cam? It almost sounds like there is no compression, with how it spins so quietly.
Really at a loss here, it's a 1 week old engine that ran flawlessly.
Thanks y'all!
rman
No. Lining up timing marks is enough.
Open valve cover to see if push rods are in place.
a lifter did fall out and i just popped it back in. That would explain the lack of compression "sound" when pulling the starter
Sent from my HTC One_M8 using Tapatalk
Did you re-cover the wire off of the yellow low oil relay with the boot after unplugging....
rman
thanks guys, it was a quick fix, both pushrods were out.
got them in place and took a quick test drive. I'm still topping out at 37mph (#35 12t clutch, 72t rear sprocket). Exact same speed, seems to bounce off "a limiter" a lot more (stock valve springs).
also need to adjust my throttle linkage more. extra spring still isn't returning back to idle.
rman
Back that dadgum 10 mm bolt on top of the throttle plate off a little!
the tension one? I actually just tightened it down, that was my idle problem. Was too loose and idle was set in an unnatural postion (plate overlapped a stop).
tightened that, backed out my idle screw, and re-bent my linkage (was a good 1/4" too long).
as far as the throttle limiter screw... that thing is long gone.
I might be out of gear... which would also mean that taking the governor out was unnecessary?
rman
Step down to a 60-68T sprocket.
eventually I will. I am an inexperienced rider (bought my kids some monster moto minibikes for their bday 2 weeks ago, I was instantly hooked).
I've laid this minibike down more times than I'd like to admit, it stands up at just a slight crack of the throttle. The other day it actually lifted while rolling about 10mph. Will probably get some higher RPM clutch springs as well.
rman
messed around with a gearing calculator, and determined that my engine was running 5300rpm before (and after) the governor removal
Definitely swap to a 60 tooth. It may not be your rpms but your gearing that is limiting your top speed.
and if you can do wheelies from a rolling start, your are definitely geared for more low end torque than top speed.
rman
A 60 tooth might just give you a 10mph speed boost. Sounds like there's plenty of torque already. Get a flywheel, billet rod and 18lb valve springs or buy a Box stock project engine and you can get up to 60mph. Heehee
based on the online calculators, it should give me another 7 (44mph).
plus it should help keep the front end on the ground.
in the future, I'd love to upgrade the valve springs, flywheel and rod, and throw a torque converter on it. But for the time being we reigning with budget!
just found a nail in my tire. Will patch it and replace it, keep it on the shelf for a spare.
Staff Murderator
...Just found a nail in my tire. Will patch it and replace it, keep it on the shelf for a spare.
You sir, are a rare breed. I salute you.
