choke on go kart shuts engine.
cobiispo
Hi, im new in the forum.
I just got a go kart so im a complete noob.
My question is what exactly does a choke do? I know you have to use it in the beginning when the engine is cold (thats what the i bought it from said). But now when i start it with the choke on the engine will barely start and if i press gas it dies, but if i leave the choke off the engine starts normally. The only thing i did was added new gas. Could it be the gas thats doing that? I think the guy put 91 octane but i added 87 so im guessing its causing that?:huh:
If he raised the compression of the engine, it may need 91 octane to prevent detonation. <Google "Engine Detonation"
The choke is used to start a cold engine. It prevents too much air from entering the intake. Less Air means a richer Air Fuel Mix. Rich mix makes for easy start.
If you try to give it throttle with the choke on, the engine doesn't get enough air.
If you can start it without the choke and it runs fine without the choke, then don't use the choke.
If the engine has been modded (since he says 91 octane, I bet it has) the carb jets may also be modded. A large pilot jet may not need the choke.
---------- Post added at 04:38 AM ---------- Previous post was at 04:35 AM ----------
Snap a pic of the carb and air filter
Let's see what you got....
Post Reply
Go Advanced
Manage Attachments
Choose File
Upload File
Close This Window
Submit Reply
---------- Post added at 04:41 AM ---------- Previous post was at 04:38 AM ----------
With my engine, I turn to choke to "Start", crack the throttle a bit, Pull the cord.
After 2 seconds I flip the choke lever to "Run" and have to tap the pedal for a minute or so while the engine warms up.
Atlanta, GA
A salmon swims in a river. He goes up to one of the other salmon and asks "why is water wet?" The other salmon replies that water is not wet, but that air is just dry. Then the first salmon is eaten by a bear.
cobiispo
alright i guess i dont need the choke. I live in arizona and its 112 degrees out here. Ill try posting pictures of the go kart and the carb tomorrow, But I have another question, Im gonna be painting it so im gonna remove all the grease or lube thats on the axle/wheel bearing. My question is what lube do i buy for the wheel hub assembly. I see that the lube on it right now is pure black and it looks thick so i cant use a 10w30 right?
Staff Murderator
10W-30 is motor oil. You need high speed bearing grease for bearings... however, this begs a question: what bearings do you have that need servicing?
Most of what we have available to us are sealed bearings that don't need to be re-packed. Photos please, or tell us exactly what kart you have and what axle assemblies. . . Photos are better though.
cobiispo
well heres my go kart. I realize my tire doesnt have bearings, or does it?
https://www.flickr.com/gp/139895509@N02/8jB8W8
Heres all the pictures. I didnt say id want to repack it, its just that im repainting the go kart so i had to remove all the grease. My question is which grease should i put on it again?
And also the engine oil is probably old so i want to change it but should i use a 30w or a 10w30? I live in pheonix and if you dont know its like 116+ here right now. Ive been doing research but people are saying that 10w30 for the summer but others say 30w, so which is it?
---------- Post added at 01:53 PM ---------- Previous post was at 01:50 PM ----------
I also posted pics of the carb and air filter(from the outside lol) if that helps.
Oh yeah i noticed on the tecumseh manual that the air filter cover on the end is removed. should i remove mine?
---------- Post added at 01:55 PM ---------- Previous post was at 01:53 PM ----------
also, the steering wheel rattles A LOT! I noticed theres a little 'play' between the steering wheel and hole it goes through(i hope im making sense) and everytime i go offroad the whole steering wheel rattles unless i hold on to it tight. So can anyone advice me on what to put between the shaft so it wont move as much
---------- Post added at 01:56 PM ---------- Previous post was at 01:55 PM ----------
so.. whaaaaaaaaaaaaaaaaaaaaa..?
---------- Post added at 02:00 PM ---------- Previous post was at 01:56 PM ----------
Yeah i dont even know what go kart this is, so can anyone tell me? there are holes that(from the looks of it) can install a roll cage. So id like to know what go kart this is so i can buy the roll cage or something. i also took a picture of the rusted clutch, and it says maxtorque or something but anyways should i change it? where can i find the product number on the clutch. And i dont even know what axle assembly this is so itd be greaat for someone to tell me because one side is bent and it makes the wheel spin bad and rattles the kart.
CLUTCH
If the engines starts and the kart doesn't drive away on its own...
If the clutch engages and starts moving the kart when you give it throttle...
If the clutch lets you do 30ish MPH...
If the clutch doesn't start on fire...
It is probably OK?????
ROLL CAGE
My buggy is high and heavy and I tried to tip it. It is not easy. It would be extra weight.?????
Your axle is above the frame. That lowers you Center of gravity even more.
AXLE
It is a live axle with mechanical disc brakes. Guessing 1".
Bearing Hangers
Bearing Flangettes
Bearings
Wheel Hubs
Sprocket Hub / Sprocket
Brake Rotor Hub / Brake Rotor
Mechanical Brake Caliper
The bearings are in the bearing hangers. The wheels (and Hubs) turn with the axle (inside the bearings). The chain drives the sprocket on the axle. The whole axle turns as the tires do.
Google "Live Axle Go Kart"
Staff Murderator
Very useful post there, Mr Obiispo. Don't see too many that are as detailed.
Neat kart I must say and a good score. I like the way it looks and that it was well taken care of. I've never seen anything quite like it but it is clear as you indicate, that it probably had a roll cage at one time.
I see your wheel hubs have what is called a Zerk fitting which is accessed with a grease gun. You may purchase a grease gun and load it with a good general purpose bearing or Lithium grease that should serve you well. Try Welfare-Mart for a suitable "greaser".
In your area and at those temps, I would use nothing but SAE 30 oil which is a single grade/viscosity. These small engines run hotter than auto engines so they need the protection that single weight oils provide. Only if you drive at temps at or under 40° F should you consider 10 or 5W-30 so you are able to start it easily when cold. A manual for this engine would have proper recommendations.
I wouldn't mess with the air filter. However, if in the future you desired more performance and less restriction, you could purchase a racing style cone filter along with a carburetor adapter to make it fit. I think there might be one available for your Tecumseh or you could DIY one.
For the loose steering wheel, having not seen the problem, you might be able to add a bushing or washer to the wheel to tighten it up. More info is needed....
Max Torque is a well-known clutch maker. The rust on the exterior is only a cosmetic issue and should not affect operation. Clutches get hot and as such, whatever paint, bluing or coating it may have had on it when new can get burnt off by the heat and then rust sets in rather quickly. I also possess a rusted clutch that otherwise works fine. I did wire-wheel the rust off as much as I could just for the sake of appearance. I'm finicky that way. :D
Clutches require knowing how to use them properly and periodic maintenance. Here's a good guide: http://www.bmikarts.com/10-Things-to-Know-about-a-Centrifugal-Clutch_ep_63-1.html
You could buy a spare clutch just for the sake of having one. Not a bad idea.
Also: the clutch can be identified by the number of teeth on its sprocket and the inside diameter of its bushing (usually made of bronze) along with other details like the internals.
Measure your axle both the length (width) and its thickness. They are rather universal items so finding a new one will not be difficult. Also consider having it straightened by a shop somewhere.
Iron John
NA
OP, I'm not sure if anyone gave you a simple answer.
The choke makes the fuel mixture richer to help starting the engine IF THE ENGINE NEEDS IT.
It will need it in the middle of the winter when the temperature is freezing. It might only need a little choke if the temperature is cool or warm.
Each engine and situation is different, so you get a feel for your motor and what it wants or does not want over time: when to use the choke, how much you need, how long before you open it, etc.
The high test or regular gas has nothing to do with it. In fact, low test gas lights up easier.
firemanjim
Just kartin' around....
Houston Texas
When operating small engines, I ONLY use the highest grade fuel at the pump. It is not like you are filling up a SUV with a 30 gallon tank. Always use the best fuel, as it aids in performance, but MOSTLY because it's just better quality. Less carb issues....
Something's you can go cheap on,...... Fuel and women are NOT two of them...... :lolgoku:
Staff Murderator
I would only add that in addition to using high grade, high octane gas with all the detergents and what-not added to it, you might consider using 100% gasoline and not the Federal mandated 10% ethanol crap. That stuff is hel on small engines especially if allowed to sit, stagnate and spoil in the gas tank for a season of disuse.
Our carburetors are sensitive little devices.
pRoFiT
Can't buy it?, build it!
California
Hellion, 100% gas! Something to invest in i guess. Looking it up i cant find a station where i live.
http://www.pure-gas.org/
Looks like there is one for the OP in Phoenix! Hmm closet one to me is in Anaheim. Bringing a gas can next time i go to Disneyland!
Does it really make any bit of difference on a small engine if you run high octane or not? Will you get any performance gain by spending more on gas?
Staff Murderator
Here's the kart in all its glory: ...going off forum for viewing is a pain for some people.
cobiispo
Wow, thanks so much for the replies! i kinda thought this forum was dead or dying lol.
So i guess i dont have to change my clutch.
Sae 30 for the engine oil
And so i have bearings on my live axle in the rear, but what about the front tires?
Theres that little metal thing on the side (not the one for the air) and i dont know what its used for, can someone explain? And for the bearings i should be putting high speed grease correct? can someone direct me to a good/cheap high speed grease. I dont know what welfare mart is but i assume you meant walmart? lol
---------- Post added at 12:16 AM ---------- Previous post was at 12:14 AM ----------
oh haha, i tried posting pics earlier but its not working. I just pres the box with the mountain and the sun icon right and post the link there?
---------- Post added at 12:19 AM ---------- Previous post was at 12:16 AM ----------
alright, i guess 113f is hot enough for the engine. Oh yeah since its really hot here in my area and i drive it for like 4 hours everytime, is that okay for the engine? i dont want it to like blow up or something especially the spark plug wire is on top of the heatsink and i feel like the weather + the engines heat will melt the spark plug wire that looks to be rubber
---------- Post added at 12:24 AM ---------- Previous post was at 12:19 AM ----------
Thanks! the guy i bought it from was selling it for 350$ but i got it for 180 :thumbsup: . Good deal or what? its a pretty durable go kart to be honest. The guy said he bought it somewhere so does anyone know what brand or name this go kart is called? where would i find the VIN number for this? :lolgoku:
---------- Post added at 12:29 AM ---------- Previous post was at 12:24 AM ----------
CLUTCH
AXLE
Bearing Hangers
Bearing Flangettes
Bearings
Wheel Hubs
Alright thanks for the post man! you saved me a few bucks and a whole lot of time. I guess i wont need the clutch replacement. and could you recommend a good grease for the bearings? like where would i find it, in the bike section in walmart or something? And yeah i dont like the look of roll cages anyway but i just wanted to know if someone knew where i can get it because what i would do is cut the cage from the top of the seat to the front of the go kart. That way the cage is only covering the engine. Then I would add like an extra seat on top of the engine lol. Because right now I just let my friend stand on the metal bars behind the engine and he just has to hold on tight!
A grease fitting, grease nipple, Zerk fitting, or Alemite fitting is a metal fitting used in mechanical systems to feed lubricants, usually lubricating grease, into a bearing under moderate to high pressure using a grease gun.
Maybe something like this. I haven't greased my bearings yet.
This should work in a grease gun. Attached to zerk fitting.
http://recstuff.com/trailer-accesso...CsU9ybl600qSR3orUrck1heHCPdK20H5dkRoCaDXw_wcB
Or one of these??
http://m.advanceautoparts.com/h5/r/shop.advanceautoparts.com/c3/wheel-bearing-grease/16167
Someone will help more. I'm just a nube too.
Staff Murderator
The forum ain't dead, buddy. We have about the fastest response time bar none. But the forum membership is worldwide and people have to sleep sometime. :p
I was very thorough in my previous reply so the answers are there.
The Zerk fitting is the little metal thing on the side of the wheel/hub you're asking about. Bob is right on track there with the grease. Good suggestions, Bob.
Welfare-Mart is Wal-Mart. You will find the grease (in the tubes or "cartridges" for grease guns) and grease guns in the automotive department.
Something about the image hosting site you're using doesn't easily provide a proper link for sharing the photos.
That's a single seat kart; no passengers. You're tempting the malevolent hand of fate by having your friend "hold on tight". If your friend wants to tag along, it's time to find him his own kart. Believe me, the fun factor will double that way.
It is an air-cooled engine so as long as the cooling shroud and flywheel fan are intact and free from obstructions, it should do fine in that environment. Make sure the cooling fins on the cylinder are also free and clear.
Check your oil often though and top off as needed and oil your clutch bushing every 2-4 hrs of constant use! Also, depending on how much riding you do, set up a decent oil change interval for the engine and stick to it. Remember, these engines don't have oil filters and they do work pretty hard when they're running so you have to change that engine oil to keep the oil clean and free of contaminants.
Check the manual for the recommended oil change interval. It will be in hours.
~Cheers
Staff Murderator
Not sure why I don't own this yet?
Because it's dinky, too small for hardcore usage and it's not GAB. I've got a standard size one (whatever that is) and it takes the more common size cartridges.
Back in the day though, automobiles (and industrial tools/machinery) had Zerk fittings all over them and to lube the chassis was a routine maintenance thing. Nowadays everything is sealed and you just ignore it until it fails then replace.
Indeed, it is out there and that is the site I used to find my sources.
Pure gasoline has a much longer shelf life too. I've read anecdotal accounts of people being able to start and run an old vehicle that sat for years with its original gasoline. This was back before E10 and E85 (gack!) existed. Barring real scientific evidence, just knowing that ethanol is alcohol and alcohol is hygroscopic--meaning it absorbs water vapor from the atmosphere also means it's no good sitting for any length of time in fuel tanks and inside the float bowls of carburetors.
Ethanol contains approximately 34% less energy per unit volume than gasoline.
In a stock engine you may not notice any performance increase but just like in high performance cars, a small engine with advanced timing and other measures will benefit highly from high octane gasoline's anti-engine knocking (i.e. detonation) properties.
&#596; &#613; &#592; u &#596; &#477; &#633;
It is Dinky but for Most Garage Kart mechanics that 3oz tube is more than enough.
I also have a standard size grease gun, whatever that is! lol
