Stator or Rectifier
SpiderSpartan
Cincinnati, Ohio
I picked up a Kohler CH12.5S-1920 engine on the cheap. It starts and runs great, but the rectifier is not outputting any usable voltage.
I checked the stator output and it's showing about 45V AC at full throttle without anything connected. I bought a new rectifier and one of the diodes appears to have blown. It's actually putting out -3V DC somehow.
My question is, is there something wrong with my stator that is blowing the rectifier, or did I just get a dud rectifier?
Are you Positive the wires are hooked up right?
I think installing incorrectly can destroy it?
Sorry I should be able to help more, but my Circuits class in college is a distant foggy memory.
And there was way too much math in Electricity n Magnetism. Lol
rk970
Coupeville, WA
This may be of some help.. I usually use one of these.
http://goo.gl/9E1InZ
Yellow to the stator, Red to positive (both actually as one is the sense line) black to ground and gray to a tachometer.
Regulates the voltage to 14.4v..
SpiderSpartan
Cincinnati, Ohio
The only thing I have hooked up right now is the rectifier/regulator and I'm sure I didn't put either AC lead on the Battery peg.
Thanks. The seller has agreed to refund this one and I've got a new one on the way. If it dies I'll look into something like that.
I got the new rectifier/regulator last night and checked it with my meter before putting it on the engine. Again, one of the AC legs appears shorted to the B+ leg. Surely it's not supposed to be this way, is it?
OK, I've read 1 or 2 posts saying you won't get an accurate reading on the rectifier/regulator without the battery connected to the system. Maybe this thing is more complicated than I'm giving it credit for and it doesn't output anything with no load on it. I'll hook it all up again and let everyone know what I find. If this works I'll be a little bummed, since I already pitched to original regulator, but at least it will be working :roflol:
SpiderSpartan
Cincinnati, Ohio
:mad2: Sure enough, once I hooked up the battery to the B+ regulator/rectifier output it started outputting 14V. Live and learn I guess. Thanks for helping me work through this.
