A few questions
weshole
So, i have this chassis im building a cooler kart from. I bought a brand new Predator 212 (non hemi) and wanted to get just a lil extra from the engine. I was looking at this kit eBay http://www.ebay.com/itm/171669693098 along with removing the governor. Is there anything more i should consider purchasing? I honestly am looking for a max speed of 25mph but i want it to get there decently. Which also leads to my next question. Im running the race tires 11" diameter that i got with the kart. Im trying to determine what gear ratio i want to run.
Ive seen so many different threads with differing opinions. I just want something more suited to what i am after with my current set up.
Posted a pic of my chassis but i will post a few pics here.
WOW.. that is an expensive kit...
that looks more like a 50 bucks kit to me...
Aaaanywhoo..
if you're really looking for no more than 25mph
you can hit that with a std 6:1 ratio and a cent clutch (once the governor is removed for sure)
And you'll get there rather quickly as well.
The DOWNSIDE:
such rear axle sprocket is rather large
i.e. a 72T #35 sprocket for a 12T #35 clutch is about 8.9" in diameter
OR a 60T #40 sprocket for a 10T #40 clutch is about 9.6" in diameter
A quite common setup tbh... so nothing to worry about too much :D
KartInfo by kartcalc.net:
Code:
[FONT="Verdana"]
[B][U]KART[/U][/B]
[INDENT][I]RW diameter[/I]: [B] 11 in | 27.94 cm[/B]
[I]Total weight[/I]: [B] 275.58 lbs | 125 kg[/B]
[/INDENT]
[B][U]ENGINE[/U][/B]
[INDENT][I]Original HP[/I]: [B] 6.5[/B]
[I]Asummed HP[/I]: [B] ~7.22[/B]
[I]Torque[/I]: [B] 9.48 ft lbf | 12.86 Nm[/B]
[I]RPM[/I]: [B] 5000[/B]
[/INDENT]
[B][U]TRANSMISSION[/U][/B]
[INDENT][I]Final ratio[/I]: [B] 6:1[/B]
[/INDENT]
[B][U]PERFORMANCE[/U][/B]
[INDENT][I]Max Wheel Torque[/I]: [B] 56.91 ft lbf | 77.16 Nm[/B]
[I]Acceleration[/I]: [B] 14.5 ft/s² | 4.42 m/s²[/B]
[I]Top Speed[/I]: [B] 27.27 mph | 43.89 km/h[/B]
[/INDENT]
[/FONT]
You can increase both: acceleration and top speed by installing a Torque Converter (series 30 Tav kit will be fine)
it's slightly more expensive than the clutch (~75 vs ~20 for a cent clutch)
with a slightly lower gearing (say 5:1)
Code:
[FONT="Verdana"]
[B][U]KART[/U][/B]
[/INDENT]
[/INDENT]
[INDENT][I]Final ratio[/I]: [B] 5:1[/B]
[I]TC type[/I]: [B]  series 30 6" driven[/B]
[I]Lowest ratio[/I]: [B] 13.5:1[/B]
[I]Highest ratio[/I]: [B] 4.5:1[/B]
[/INDENT]
[INDENT][I]Max Wheel Torque[/I]: [B] 128.05 ft lbf | 173.61 Nm[/B]
[I]Min Wheel Torque[/I]: [B] 42.68 ft lbf | 57.87 Nm[/B]
[I]Acceleration[/I]: [B] 18.54 ft/s² | 5.65 m/s²[/B]
[I]Top Speed[/I]: [B] 36.36 mph | 58.52 km/h[/B]
[/INDENT]
[/FONT]
the max-torque is what provides the acceleration, and well top speed is self explanatory ;)
Bonus: you'll gain sprocket clearance :D
weshole
Any links to similar parts that i shown in the ebay kit?
Also, do you have a link to such a torque converter?
Again, i know i can find it as well. Just figured if you already knew of one, youd know the most cost conscience place to get one.
---------- Post added at 08:36 PM ---------- Previous post was at 08:36 PM ----------
That kart wants to go faster than 25 mph. It told me so.
Oh im sure it does and i will get there soon enough.
If you wait, after work, I can save you a few bucks by getting the items individually.
---------- Post added at 08:56 PM ---------- Previous post was at 08:56 PM ----------
And that would require a jack shaft as well?
Nope it is built in.
check ebay every now and then..
ATM the best price for a TAV Kit I can find is 80 (I've seen em for 72 already)
http://www.ebay.com/itm/COMET-TORQU...-CLUTCH-3-4-30-75-12T-35-10T-41-/122037259865
Airfilter and adapter are 15-16 each on affordable gokarts..
the muffler ten.something
leaves us with 43 for a headerpipe and the jet (a jet you can easily resize yourself)
no need to swap the emulsion tube just yet (IMHO) so 4 bucks for a Honda jet (say from amazon)
39 for a header... seems expensive to me.
considering the AKRA header costs less than 30 (on ebay for example or on AFGK | and has no muffler at all)
So the ten.something can be substracted again.
That may not be cheapest. Maybe 75 with free shipping?
yes bob.. I can't see ALL ebay.com in correct order from germany..
that's why I said "cheapest I can find"
that one shows up to me as well..
but with this nasty shipping addendum:
Versand:
US $2.000,00 (ca. EUR 1.806,60) Expedited Int'l Shipping
see?
So yeah... I can't search properly for cheapest auctions (only incl shipping.. and that throws it off)
With a TC you just add a chain and axle sprocket. Maybe a hub for the sprocket
---------- Post added at 09:38 PM ---------- Previous post was at 09:14 PM ----------
see?
I meant MY first link may not be cheapest. I wasn't trying to underbid you. Lol
weshole
Ok, with posted torque converter.... do I have options for putting a taller (smaller tooth) sprocket on the axle to gain some more top speed while maintaining some low end response vs. a plain clutch/sprocket set up?
And as far as the mod pieces for the engine, (air filter, jet, exh, etc.) Im ready to pull the trigger right now and order. So, if there is a less expensive option... Im all eyes (ears lol)
---------- Post added at 10:18 PM ---------- Previous post was at 10:05 PM ----------
Oh, and i dont care if it has no muffler. I know it will be louder. But just want it to breathe.
I dont think that first KIT is too far off on price at 8 and free shipping.
Yes lit Sid said 15 an16 for the intake and filter but that kit also has the Choke holder piece
and jet and emulsion tube. Plus headers ar more like 30 not 10 and you get a muffler.
Add in Shipping and anywhere you will be at about 80 bucks.
So not the Cheapest kit but you will NOT be getting ripped off if you buy that one.
---------- Post added at 08:24 PM ---------- Previous post was at 08:23 PM ----------
But I shop here and get 10% off With code DIYGOKARTS
http://www.gopowersports.com/go-kart-parts/performance-parts/
weshole
It also has a 4 degree woodruff key for the crank. Or, is that not as big of a deal?
Assuming in the 48...
For the flywheel key.
If you already have calipers, you can file it yourself and save $10.75 USD.
File 0.006" for Every 1 degree. 8 degrees = 0.048"
"This is a stock flywheel key that can be filed to advance timing. Every 0.006" you file off is equal to 1* advance. Example: remove 0.048" for an 8* advanced timing key."
http://www.affordablegokarts.com/mm5/merchant.mvc?Screen=CTGY&Category_Code=CF1
For the 0.036" or 0.037" Main Jet.
I got Micro drill bits from HobbyTown USA. They were less than $2 each. Drill the stock one to 0.036". It's easy. If not happy drill again to 0.037"
Exhaust Header.
w/muffler...
$25 plus $8 shipping (TO ME)
https://www.ombwarehouse.com/Weiner-Pipe.html?category_id=718
without muffler...
This one is CNC Ported. (Looks like mine)!!!! $35 free shipping
http://www.ebay.com/itm/Clone-Heade...ash=item2ed1ff1fbc:g:GpAAAMXQh8NTd1QB&vxp=mtr
For the Muffler...
O'Reilly's carries them for $7
http://www.oreillyauto.com/site/c/d...+muffler_-1_4751&keyword=small+engine+muffler
So $42 for the ported one, around $33 for the non ported.
Air Filter Adapter/ Choke Braket / Air Filter / Prefilter
$32 free shipping.
http://www.ebay.com/itm/Clone-Air-F...ash=item2ed2262718:g:olMAAOxykUZTe5nm&vxp=mtr
Or combine with OMB exhaust for no extra shipping.
This comes with long carb stud and gasket if you need it, but no prefilter. ($30)
https://www.ombwarehouse.com/predator-212cc-clone-196cc-air-filter-intake-kit.html
gx140 Etube
$9
https://www.ombwarehouse.com/BSP-Clone-140-Emulsion-Tube.html
no extra shipping
THE KIT PRICE IS GOOD. YOU CAN ONLY SAVE A FEW BUCKS AND WILL COST SOME TIME AND EFFORT.
---------- Post added at 01:20 PM ---------- Previous post was at 01:07 PM ----------
$76 is the best I can find and it involves shopping around, some driving, drilling, filing,.... And need $15 calipers as well.
Exhaust Header.
w/muffler...
without muffler...
For the Muffler...
$32 free shipping.
gx140 Etube
$9
no extra shipping
$77 is the best I can find and it involves shopping around, some driving, drilling, filing,.... And need $15 calipers as well.
This ^^^^^^ from a guy that drove an hour and a half for a gokart chain?:rolleyes:
