A few questions
weshole
I went and bought this kit.
http://www.ebay.com/itm/171666517229?_trksid=p2060353.m2749.l2649&ssPageName=STRK:MEBIDX:IT
It only made sense to get valve springs too. I dont want to chance it. So, the lil extra $$$ was not that big of a deal. I got the chassis crackhead cheap. So, I have a lil more budgeted towards the add ons.
Now, to figure out gearing.
Im contemplating a final ratio of 5:1 with 12t on the drive and 60t on the sprocket. Is that too tall? Weight wise, Im 225lbs alone and whatever the karts final weight will be.
Poboy kartman
Senior Moments Member
White Settlement Texas
Yeah...well...apparently...OMB is stupider than my pet turtle...they sell this BS kit with 18 lb. valve springs...(don't even get me started...) and then say : "A billet flywheel is recommended if you remove the govenor.....ummmmnn REALLY? HOW ABOUT A CONNECTING ROD?
And why would you through money at an engine and leave the govenor in?
It just goes BEYOND ridiculous!
JFYI: You can safely remove the govenor and the risk to ANYTHING stock is minimal. Add 18lb. valve springs and the risk to the stock connecting rod comes into play...the stock FLYWHEEL however...is good to over 6,000 rpm.
Seriously, screw those billet flywheel pushers...call GoPowersports....they got a guy that squeezes over 20 hp out of the 6.5 Predator...just talk to them...they won't sell you crap you don't need.
Ya that's how they roll overyonder... Will ban you for going against that thinking, out loud in there forums aswell... No gov must have a machined flywheel. Period and no other exceptions.....
I'm not too fond of there overall attitude... Albeit I do look overthere... I don't post much...
So Poboy is saying "cliff notes"
Don't put the springs in unless you also get a billet connecting rod.
---------- Post added at 09:03 PM ---------- Previous post was at 09:00 PM ----------
I like what used to be Bob's a little better!!!
---------- Post added at 09:07 PM ---------- Previous post was at 09:03 PM ----------
But there is current experimentation going on.
Me testing the flywheel at 6500-7000.
Others are set on testing the Conrod above 5400.
I'll be honest if it goes. I'm sure others won't speak up, cause of the I told you so's
weshole
I dont plan on the billet flywheel or the con rod either. The rod may come down the road. But I really dont plan to rev the ever lovin piss out of her all the time much less hopd sustained high rpms either.
No billet con rod no 18lbs springs then!
Since frankly.. it's not necessarily constant load that weakens the conrod, it's the load CHANGE that drives it crazy.
I bet you can rev a original honda conrod for 7k and 8k without problems..
(slowly up to and slowly down from... ONCE)
Chinese clones (and that definitely includes the predator here) ... I wouldn't even try ONCE!
Sure, it's very well possible it'll hold a minute or two.. even a day and a half..
but it's equally likely that it breaks on the very first attempt to rev to 6k
And at that speed it'll pop a chunk of crankcase towards your neck...
ONE failure is enough to get seriously injured or even killed...
No really.. open the trashcan, drop in the 18lbs springs.. move along
(or put them on a shelf label them "billet conrod only!" and forget them)
What I don't get is when every person says one thing,
And the OP is like nah?
Kinda guilty myself with the fuel pump.
Also guilty with the flywheel according to other forums.
Poboy kartman
Others are set on resting the Conrod above 5400.
EXACTLY!!!. Like so many "INNOVATIVE" ideas...that just melt away.....hmmmmmnnnn?
weshole
Well, if I read the comments correctly, Im looking at revving to between 5000 and 5200 rpm. Am I to assume with the current mod path I have chosen that the revs will climb higher? Also, will the $80-$90 connecting rod solve the issue alone? Im trying to learn here. Not nay say what you guys are telling me.
---------- Post added at 11:02 PM ---------- Previous post was at 10:53 PM ----------
Also, if i dont install the springs, will that effectively keep the revs to a safer zone?
leesiel
Yardcart 196
Savannah G.A.
I will keep you guys posted on the 18 lb springs with no rod.
I am in no way saying this is safe or recommended . I have a shield going behind my seat for protection. DO NOT TRY THIS AT HOME.
weshole
Ok, i removed the governor and oil level sensor last night while i wait for the parts tonshow up. I am still looking for advice on gearing. Do I gear 5:1 or closer to 6:1?
That's what ive narrowed it down to. Any input?
chancer
ɔ ɥ ɐ u ɔ ǝ ɹ
COMFORT, TEXAS
I would go 6:1 so it does not bog down when the cooler is full of beer and ice!
Besides 5:1 is really only gonna get you a better top speed 30+and will only work with smaller tires like 10 or 11 inch.
Oh yeah you have a Torque converter. Either one will work then.
weshole
I haven't purchased a TC yet. I may just do a clutch and gear 6:1 to get this going. I have limited funds that are set aside for the initial build. If I go the clutch route, it will only be temporary.
weshole
Pulled the trigger on a TC, hub and 60t sprocket. Gonna try 5:1 ratio and see how it works. Any other words of advice?
