YerfDog identification
JollyKarter
Texas
I believe the 3202 was black (which is what I have), I think the red was 3203. Of course, if that isn't original paint, all bets are off. Also, my 3202 doesn't have the fancy logo on the seat. Do you have any pics of the back? I am guessing the roll cage has been removed, I can see the tabs on the front where it would have mounted.
Not really sure, but it looks like it has adjustable shock mounts on the control arm. Is that correct? My 3202 does not...now some may have, not sure. Another difference is the 3203 had some sort of little rack over the motor. Can you tell if it had something like that originally?
Staff Murderator
Just the name alone is a deterrent to purchasing. :ack2:
Word is that the founder's name was Godfrey, so in an act of desperation from writer's block he simply spelled his name backwards, gave the name to his creation and the rest is history.
Duckie92
Arizona
I'll post more pictures later. $220 for it. $20 from that is for gas for him to drop it off. All he said was wrong was in needs brakes:)
Duckie92
Arizona
Here's a picture of the back. To bad it doesn't have the roll cage though /:
Duckie92
Arizona
I think it use to be black telling from this picture under the bar is still black and you can see the YerfDog sticker still.
JollyKarter
Texas
So that is interesting...It has the same yellow/chrome shocks on the rear as my 3202, but it has the black/chrome shocks and adjustable shock mount on the control arm like a 3203.
I would say that seems like a fair price if it starts and runs. They have a kind of crappy drum brake on them originally, so it would be a good excuse to put a disc brake setup on it. Also check the rear swing arm where the bearing mounts next to the brake assembly. The Yerf is bad about the tubing of the swing arm bending there. There is some excessive force placed on that part of the swing arm frame when you gouge down on the brakes and causes it to bend. Might be a price chewing point if there is damage there.
Staff Murderator
So... Duckie. How many karts do you have and what condition are they in? I've seen several of your build/restore threads and heard that you had one or more crashes. The attrition rate on your karts must be quite severe!
Duckie92
Arizona
I have 3 go karts including the one im restoring and a Yerf Dog Spiderbox. I use to have a Yerf Dog 3002 but sold it because the breaks stopped working and the operson i bought it from welded the drum break to the axle. I've crashed once with my YerfDog 3002 but fixed that all up. It turned to wide still but ran and was pretty fun.
Duckie92
Arizona
JollyKarter, are you talking about this top bar or the bottom one?
