YerfDog identification
JollyKarter
Texas
As far as the one that bends, it is the lower portion of the frame that the axle mounts to on the left side. Excessive hard breaking can cause them to bow. I need to straighten mine it...it isn't difficult, jus another thing to have to do.
trkk11
New Lenox, IL
Looks exactly like my 3202. Some asshat that had it before me cut off the bar over the engine, cut out the section behind the seat, and mounted the shocks to the ends of the cut off bar. I have my work cut out for me, but I'm pretty confident I can get it back to normal!
Duckie92
Arizona
Got the go kart today :D Looks perfectly fine. Little bend on the A-arms but not to bad. Waiting for this rust removel to soak so i can get the rear wheel off to see the break band. Seems like it might be to big for it or has alot of slack that it's not gripping the drum break when break is pressed. Well seems like the wire is to long for the breaks. I cant get it any tighter then it is /:
Duckie92
Arizona
This is the band break. Looks pretty worn so will buy a new one soon:)
Duckie92
Arizona
When brakes are applied it barely pulls the brake band and has a little space left. User manual says the drum is 4" and brake is 4.2. Should i still get a 4" one?
Staff Murderator
It's not even fully engaging the brake drum; look at that narrow wear pattern! :eek:
I can't see the metal backing on the brake band and so therefore, I cannot help you measure its thickness....but it seems to be fine?
Duckie92
Arizona
Yeah it's only gripping someof it but i don'tknow why. I might have to move the bolt that holds the band back more would help.
Staff Murderator
Well, I suggest looking at the brake band and stepping on the brake a few times. Watch how it engages. The brake band could be bent or warped so that it's not flat on the drum when it engages. There could also be a bent mounting bracket--on one of my karts, wait, on two of them the bottom part of the band is looped of course, and attaches to a peg that is welded to the kart frame. If the mounting peg is bent one way or the other, it will bend the band over at the same angle as well, causing horrible brake engagement.
It may be trash though and need replacing. I'm keeping mine the way I bought it as long as I can though. Then I might upgrade to mechanical disk brakes.
---------- Post added at 09:33 PM ---------- Previous post was at 09:13 PM ----------
Oh yeah, for better looks and performance, I'd ditch those front wheels/tires and get something a bit bigger. Compared to the rears, those wheels look abysmal--and it makes the kart look like a dork! :D
