Predator 212 help!
Bmforrest1515
Parrish florida
So a little update... Ordered .018 and .019 idle jets. Neither make it run good. In idle it will sit around 2000 and bounce up and down for about 2-3 minutes (between 1800-2100) and eventually die down to about 1400 and die. If I turn choke on with the .018 it will run forever. I'm trying to read the plug on it but can't seem to get a good read, seems a little lean to me. The center electrode seems to look very clean around the tip when I pull it out, that doesn't seem right to me. Any tips on how to get a good read on the spark plug to judge good idle? Amount of time to let it sit, should rear tires be on or off ground, should I drive it also? Thanks
You pretty much can't read plugs to adjust idle....you just have to go by performance.
Joe-405
Enjoying New Projects
U.S.A.
Give me til tomorrow. I will pull the plug in mine and show you what I haven't changed in forever. I betcha it's on the blackish side tho.
Hey Joe. You would know. Is a high performance engine even meant to sit and idle. Doesn't it get "loaded up"? and die (stall) eventually?
cavfire
auburn, georgia
You could try adjusting the idle mixture screw as well if it isn't tamper resistant. Will be on the side of the carb just to the left of the low speed jet. I run them in until they seat while counting the number of turns for a baseline, always want to know where it was originally! Then back them back out to where it was and try 1/8 turn adjustments in or out from baseline. Being able to adjust this really helps once you start doing intake, exhaust, and jetting changes.
Sounds like the idle circuit is lean though when you say it will run fine with choke on plus earlier you stated it seemed to run hot. You've got extra low speed jets now, and if you have a micro drill bit set you can start going up one size at a time and testing.
It hasn't been mentioned, but those ARC flywheels throw a LOT of timing at these motors. That's all well and good for a race kart turning 7,000 rpm and idling at what used to be the governed max with a high stall clutch. That motor isn't going to turn that on a 600+ pound golf cart though. I would pull some timing out of it. Stock timing on the clones is a bit across the board, I've read 20° is the spec on the GX200 but measured my clone at 24° with a degree wheel and timing light. It won't cost you anything to swap your old flywheel back on and see if it helps idle, and if it does you can use a reverse timing key with the ARC flywheel to drop timing.
Bmforrest1515
Parrish florida
I appreciate all the replies. Yes I have messed with the mixture screw,I will pull the stock flywheel on today and see if that makes any difference. That's the only thing that I have run across that I can't test for as I don't have a timing light
Joe-405
U.S.A.
Mine will sit and idle and run just fine with all the mods I got. It's a bsp engine so it's actually got more done than yours does. If you go to my okie barstool thread in the buildoff section from 2 years ago you can see everything it has. I literally haven't even broke open the spark plug since I built it. So yours has something weird going on.
