Runs on 12v
Sent from my SCH-I545 using Tapatalk
I understand water in combustion chamber but small droplets is that big of a problem. They use Water Methanol on gas engines even some small single piston engines with great success. The small water droplets should reduce volume in your combustion chamber and then be evaporated when the combustion takes place. ...
They'll evaporate just fine, that's not an issue, but by doing so, they swallow a lot of the combustion energy maybe more than you gain from cooling the air/fuel mix.
but let's ask the physics nerd shall we??
Attention math ahead!
Let's do some basics first..
One Joule is the amount of energy to increase the temperature of one gram of water by ~ 0.239 Kelvin
since the Kelvin scale equals the ever so convenient Celsius scale
in which water boils at 100°C and average ambient temperature in spring is about 20°C
We need to increase by round about 80K
for simplicity let's assume our water droplet has a weight of 0.01 gram
(mid sized droplet)
to evaporate said 0.01g water droplet we need to add ~3.4 Joule of energy
A Joule can also be written as a Watt second..
In which case and under the [false] assumption that a single combustion would take a second it'd literally "evaporate" 3.4 Watts
which doesn't sound like much, but the actual combustion doesn't take nearly as long..
in fact @ 3000 rpms you'll have 50 revolutions per second,
so a combustion cycle alone is about 1/100th of a second only.
(the combustion itself is even short.. but let's just stick with nice numbers)
So in order to heat up our small droplet in 1/100th of a second we need to feed 340 Watts of energy (heat) in!
A Honda GX200 (6.5hp 4.8kW) @3000 rpm produces roughly 4kW
end of science...
And with that evaporating the droplets alone will
swallow 8.5% of the motor power.
True, the droplets can be smaller, but 20°C (68F) isn't that cold..
and the colder the water, the more energy you'll need to boil away the water
and even if the expanding water vapor is able to regain 80% of that loss (which I doubt)
you still loose 1.7% of motor power because of the water
See...it's all about condensation and the energy it takes to absorb it!
Soooo....if Alex could condense his posts....it would take less energy to absorb them!
(Like that's gonna happen! )
My 2 cents.
One major concern I have is how much condensation will be created in the fuel tank. Cold fuel will act as a platform for water to condensate.
I think you would be much further ahead to build a cool can with coils of copper tubing inside. With all the alcohol in fuel these days I would be leery of even trying that. However I would consider water/methanol injection not only would you cool the fuel but the incoming air also.
My 2 cents.
New to the forum, I have a Predator 212cc engine that have been wanting to customize for the fun of it. Looked at adding a turbo (been done), looked at adding super charger (been done), wanting something different and unique. Most Drag Racers (cars) use some type of cooling for their fuel and some also cool the air before entering the carburetor. First question is has anyone on forum tried it on a 5 to 6.5 HP horizontal shaft gas engine? .
Sounds like a PAFR idea to me. Go for it.
Noooo. it would work for an intercooler but i dont see a need for it here.
and fuel is already cold. havent you had some drip on your hands from the carburetor?its pretty cold. unless you are trying to make your motor more fuel efficienter and run lean.
But there is a thing called "Cold Start"ing which makes a vehicle much harder to start especially on cold mornings because the gas (due to science and cold temperature) is more of a liquid and not heated up well into..a gas. I don't know if the same is applied to carb engines.
Just because gas feels cold on your hand dosent mean it's cold. Your hand will feel cold because when the gas is evaporating it is is actually stealing heat from your hand in the process. Hence your hand feels cold.
Again Evaporative cooling. It is Hot out, the gas is expanding or Vaporizing or Evaporating, so fast it causes, the air cools and it causes, condensation. On a humid day there is more moisture in the air the condensate vapor drips and freezes!My 1956 terratrac bulldozer has a problem with icing of the carburetor only on hot and humid days though. Figure that one out.
