To replace or to remove clutch?
chin_lee
Pacific Northwest
OK something happened and my previous post was accidentally removed.
I'm a 42 year old noob to gokarts but I am mechanically inclined. I am hoping to get some good advice and opinions on my options.
I bought a project Murray go-kart to work with my son. It currently has a Powerfist 6.5hp engine. I was looking at the clutch, engine and sprocket and it was about 1/4 to 1/2 inch off. I removed the wheel/sprocket/brake assembly and determined it will be easier to adjust the clutch rather than modifying the frame. I removed the outer clutch cover and the inner assembly leaving behind the center part of the clutch on the engine bore.
Here is the picture of the outer assembly.
Here are pics of the inside clutch assembly
Should I be replacing this clutch? I am not familiar with how much wear is on the clutch.
Here is some pics of the center piece on the bore.
Here is pic of one of the holes to secure the clutch to bore. I don't believe the previous owners put the bolt in there.
Here is a pic of the other hole.
Here is a straight shot of the bore.
Is there suppose to be a bolt on this?
So my other questions:
Should I replace the clutch?
If so, should I just angle grind that center piece off? I tried getting that piece to come off and its not budging at all.
If i do angle grind it off, I do grind off that shiny smooth metal piece as well?
Any advice, help and opinions will be greatly appreciated.
Thanks
You should replace it, but make sure to remove the star hub from your shaft as well, that is part of the clutch (and there will be a new one with your new clutch)
ther are two holes for a grub screw, check if one is in place... (IIRC 90° offset)
The clutch you have is a Maxtorque SS, which is also what I'd recommend to replace it with.
Since you have a 6.5 hp engine you'll need a 3/4" clutch (check your shaft diameter to verify!)
Just count the teeth to buy a correct replacement.. 12Teeth will be a #35 chain 12T and 10 Teeth means you'll have a #40/#41 chain so the #40 10T will be the correct replacement.
Yes, you can repair your clutch, but with the parts you'll need you'll likely pay as much as you would for a new one (around 30 dollars)
You can put a bolt in that hole, It will be a 5/16 fine thread.
You may be able to carefully Drill out that set screw in pic 5 and 6.
Also thumbnail pics are preferable on this Forum.
wow... never seen one sploded that much... need a new one for sure.... the princess has them for a good price... they're pretty decent.
Id use some heat and see if the puller can grab the star hub and pull off the reminants... if not... use the cut off wheel... down to the shaft... but not the shaft.
chin_lee
Pacific Northwest
is there a set screw?
Thanks for the advice. I've looked at the two holes for a very long time and I don't see set screws in either hole. Are you see something I'm not seeing? Please let me know what I'm missing
Oh your right sorry.
There is another very similar thread tonight.
Get some PB blaster (not WD40) and Soak that thing a few times a day for a few days. It should come loose and slip Straight off.
Or WD40 Specialist penetrating oil.
chin_lee
Pacific Northwest
puller didn't work
Well I tried heat gun and puller on the little nubs on the star hub. Broke one nub, repositioned, more heat, more PB, turned the bolt and broke another nub.
My puller can't fit between the star hub and the engine because its too close so it can't grip the main section of the star hub.
Should I reassemble the clutch and allow the puller to pull on the back metal plate of the clutch?
Or should I just use the cut off wheel and go to town on it?
Going to need real heat, as in a torch.
You might need a bearing puller plate to get enough bite inbetween the block.
If you put it together, I think just a spring clip holds it togrther, So you will break it too.
---------- Post added at 10:36 PM ---------- Previous post was at 10:35 PM ----------
Oh yeah Fabroman made on of those.
---------- Post added at 10:45 PM ---------- Previous post was at 10:36 PM ----------
Here make one of these:
http://www.diygokarts.com/vb/showthread.php?t=18898
A Word of warning, do not use brute force too excessively,
you don't want to break anything inside.
keep in mind that the crankshaft is supported by nothing but two bearings you want to keep alive and is connected directly to the conrod which must stay perfectly straight.
You know you have to spray penetrating oil onto the shaft; not the sleeve that's still with the hub and covering the shaft, right?
Anyways, after penetrating oil, and a good amount of heat (you need at least 200°C or 400F)
try to rotate the hub clockwise while pulling /pushing it off.
I think your key might have been sheared and is now stuck between the shaft and the sleeve.
chin_lee
Pacific Northwest
thanks
thanks for the info. I'm not going to risk damaging the crankshaft inside since I'm going to be replacing the clutch anyways. I am going to angle grind this thing off. I believe your assessment is correct about the key being sheared and if that's the case, I really don't have any other option but to cut this thing off.
I'll update after I but the angle grinder to this thing. Shouldn't take too long.....I hope.
Thank you all for your support and advice. Much appreciated
chin_lee
Pacific Northwest
update
Hey guys
So i put the angle grinder onto the clutch star hub and dang it went through that hub like butter. In fact, it was so fast, I did get a chunk of the crank shaft. Here are the pics of the shaft after removed the sleeve and star hub.
Here are the remnants of the star hub and sleeve
Cleaned off the shaft with carb cleaner and light sanding and it looks like new!
This piece was providing tension on the chain via the spring.
Do I need to put this back on? Or can I get away not having it? I have watched a few kart builds and nobody puts this on their chains.
That is a chain tensioner, A couple karts do use them. just depends on the design.
We would need pics of entire Drive line to say for sure if you need it or not.
