Need help with a go kart I just bought, alot a help lol.
Ryansway2005
Tennessee
Hey
I just bought a go kart for my daughter and needing help, and I'll post pics below, but I rebuild motorcycles and scooters so I got alot of parts just not familiar with the predator motors and these carts,
First question: What brand of cart is this ? I tried google but can't get a positive I.d.
Second question: What type of throttle cable would I need to use on this cart, any suggestions is greatly apperciated.
Third question: This is what I learned to be a dead axel go kart and it needs lug nuts but not sure the type, the guy I bought it from had normal nuts on the axel and it was pinching the hub and not letting the tire tuen any suggestions.
Fourth question: Any 1 got any good ways to rig up a set of lights to a go kart?
http://s33.postimg.org/hl1b7qkrz/1464586279404.jpg
http://s33.postimg.org/nd7g2aban/1464586413296.jpg
---------- Post added at 11:38 PM ---------- Previous post was at 11:34 PM ----------
http://s33.postimg.org/5qs8bik6n/20160529_043734.jpg
---------- Post added at 11:42 PM ---------- Previous post was at 11:38 PM ----------
http://s33.postimg.org/9z788qawf/20160529_043853.jpg
CalebJns
Alabama
what engine is on it? look up the specs...worst case you could install a battery and just put it on a trickle charge at night (when needed).
It looks like a Carter Brothers 2606 or Shadow. Can't tell too much from the dark photos.
It's a 212 predator/ harbor freight motor
Looks like the carb's been modified. Orient your phone cam properly (so I don't have to turn my head sideways) and take some pics of the butt end. :D
Now these throttle rods I keep seeing--I don't know how they're supposed to work because it ends behind the seat. I guess the rest is supposed to be a flexible wire cable which doesn't make a lot of sense. A lot of the Manco throttle cables have an eyelet loop on the pedal end and it fastens simply to a bolt there. The other end is the usual attachment you see on roto-tillers and pushmowers.
Ryansway2005
Tennessee
Ya I didn't care much for the throttle set up, and ya I've never posted pics before so my bad on the crappy pics, so any suggestions on a easier way around the throttle setup? and ya I modified the motor lol
Pics. are easier to see and enlarge if you use the Forums Attachment option.
click this
How about a straight "bicycle cable" type from pedal to engine? But what I lamented on earlier is the exact way these hybrid throttle 'activators' are set up on these karts. Maybe the designers were on to something?
I believe there should be a cable clamp or just the remnant of it in the form of a post or metal strap welded to the frame near where the throttle rod ends. You could set up a short length of sheathed cable from there to the engine. Looking at a similar kart manual from the below source, one throttle cable was only 31" long. There's a lot to look through:
http://www.gopowersports.com/go-kart-breakdowns-user-manuals/carter/
