Cant decide on a power train
bread
maryland
few pics to show wheel placement /stance, I'm currently trying to figure out how to put the bearing balls back in a cv joint, to me, seems frustrating
front hubface: 71" (adjustable)
rear hubface: 60" (fixed)
comments? thoughts?
Atlanta, GA
Your drive shafts are long enough to connect to the diff? I admire the work you've done so far. Did you decide on an engine?
bread
maryland
thanks, the DS's BARELY make it to the yokes
as for engine, since this is my high school senior project (don't worry not a senior yet) I want to do something "innovative/new" or whatever so this thing is gonna be 'lectric
this is the power system I've decided on, IK the price is steep
anyone with electric power systems knowledge, please chime in
http://www.electriccarpartscompany.com/72V-VW-40HP-br-DC-Motor-br-EV-Conversion-Kit_p_559.html
Holy Heck! Not cheap! Now I know why I don't read in the electric section. lol
Cool Project!
bread
maryland
wow its been a while, guess i'll dig up my thread
the car thing has been moved to my shop so work space is much tighter
the rear axle has been built and shocks are on the way, very close to being a roller. definitely will not be using such wide tires in back
only this pic for now, more to come
bread
maryland
Another update, the front suspension is done as well as the rear, now to mount the diff. Figured out how to attach the vw axles to the bmw diff, I had a machine shop bore the flanges from 5/16 to 3/8 and they fit perfect now
shock clears axle
bread
maryland
Axles reach barely, diff mounts being created now
Does anyone see how else I could power this? Just wondering if a single speed could be done on this scale with an engine?
tinamcjittles
ello m8
Allovau
If it will be electric you can just attach the output of your EV motor directly to the axle! No clutch needed!
84hp will be sick man, can't wait to see this done!!
bread
maryland
Thank you for the comments
tony, what i mean is does anyone see a way I could power this with an engine like combustion engine
some pics of it finally sitting on its wheels
Could find an old rear wheel bug and use the engine and transmission. Or make a manual clutch on a small gas engine and put a sprocket on the rear diff to the engine with a #420 chain.
Exhaust enters the turbo, witchcraft happens and you go faster.
bread
maryland
There is no rear diff
