NEW Designs! Re-Imagined Clutches!!!!! Dynamic Suspensions!!! Go-kart from ****
I DO!!!! But it doesn't make it any better....I think I layed it all out a few posts back.....:surrender:
It's like: "Watch this! Somebody hold my beer...make sure you get a good shot of my head sticking out of the barrel as I go over the falls!"
For those noobs who are not sure what PAFR means, it is "Pulling a FreeRunner". You will have to work out what that means for yourselves :D:D
Inside Jokes are not funny when you explain them to the noobs.:2guns:
It is way better when they get a post from FR and then suddenly see the light.
Like what happened to "relativity" the other night.
mkIVgladiator
upstate albany New york, united states
New Dynamic Tensioner Suspension! New improved clutch Design! The real Deal
clearly you see failed engineering in the form of a inadequate clutch, i defiently improved the design by welding half cut out round stock and centered the fly wheel so it makes zero noise while idling...pour as much oil as you want on it ... it will wabble and rattle unless you hook it up to a bearing to center the flywheel
i make a positive air respirator so u don't have sweat building up in your mask while your welding
the go kart has a bunch of spacers i had to keep welding on to get it up high enough... should of put solid steel but just kept adding half cut out round stock
i am adding an extra spring to the tensioner since this is going to be a purely tensioner design...
brakes are yet to be installed. All of the go-karts videos above are probably worse rides than this one....
this one seater has a dynamic single coil suspension and tops out at 40-45mph friend clocked me going up hill on a road. This go kart has....
-$90 heavy duty ebay 1 inch bore clutch has been re-engineering
-$50Tecumseh 10hp motor off of a snowblower ...purchased
-$80 go-kart complete chassey wheels and everything else off craigslist
-$5 bicycle cable attached to gas pedal.... throttle has a retract spring
http://i66.tinypic.com/rkda2q.jpg
http://i67.tinypic.com/15gv72w.jpg
http://i68.tinypic.com/35mio05.jpg
http://i67.tinypic.com/vo7txe.jpg
http://i64.tinypic.com/2dt7gvm.jpg
https://www.youtube.com/watch?v=l7bV-g7fHEc&feature=youtu.be
You're still an idiot... You can't even capitalize letters , resize pics, or fill out a profile location....
And your crap SUCKS almost as bad as your ideas.
And as if it wasn't enough to pizz us off already...you start ANOTHER THREAD ON THE SAME LAME SUBJECT?
Put down the crack pipe and walk away...BTW...What's it smell like with your head that far up your butt?
Nope Gladiator, another thread with the exact same topic and missing info isn't going to happen!
So I merged the two!
Just because you didn't like the comments, and you didn't like to make a good plausible explanation (or you cannot for this matter)
doesn't mean you can start over with a fresh thread posting the very same crap again,
failing to explain again.. and causing -again- the very same comments.
Atlanta, GA
You old post was inserted in to your new post and put in the post on top of the post to left of the uppermost post so that when the post breaks, the posts raining down in flaming embers don't land on your new post, causing post-posting postitis.
Say man...don't be gettin all postal up in here and stuff!
