Desertduler
- Messages
- 1,736
- Reaction score
- 11
No, you will be fine, just make sure that at wide open throttle the oil pump indexing marks line up together, I do not use oil injection I mix my fuel with oil 25:1 air cooled two stroke oil. Do not use tcw3 oil which is formulated for outboard motor use as it does not have good enough film strength for air cooled two cycle engine use. Make sure that the axial fan belt is in good condition and adjusted properly and check all the cooling fins on the cylinders and cylinder heads and make sure that they are free of any debris of any kind and clean them if needed and for sure do not use a K&N filter or any fabric filter like them as they let dust through them which in turn will eat your engine components up, use a foam air filter and treat it or them with foam air filter oil which is very sticky and traps dust,dirt,sand,etc.Is there anything I'd have to do to the engine besides adjusting the carbs and oil pump for warm weather? Anything to help with cooling the engine?
Here we go again....
