I'm not 100% sure I have this carb reassembled properly, but I can't seem to find a breakdown anywhere? ????
Help?
Help?
Help?
Is this a joke? "my pulley spins, any help?"
I assume you have looked at this and concluded your's is from a different Tecumseh dimension?
http://outdoorpowerinfo.com/repairs/tecumseh_vector_carb.asp
Nope....if I had found that...I wouldn't have been asking for a breakdown. Even though that doesn't show a breakdown...it showed me enough. Thanks for the help!
It's the same old dilemma now....new one is on the way,(hopefully the correct replacement,) because buying replacement Tech carbs costs about $1 more than a kit!
The O rings were shot in the one I had....I didn't even know there was one at the end of that drain assembly! And...I didn't have it assembled correctly...(the emulsion tube/spring...)
That link is on the Helpful Links sticky. Looks like you were doing a freerunner by not searching![]()
Doing a Freerunner: DAF Oh that's funny.
http://www.tecumsehcarburetorguide.com/tecumseh-parts/
"Another best part about the guide offered by us is that you can see in-depth parts detail of every Tecumseh carburetor that is available. "
Not sure if this helps. Lots of carbs in this one. Now Break It Down! -MC Hammered
---------- Post added at 01:24 AM ---------- Previous post was at 01:21 AM ----------
One of my favorite ways to surf the web is to search Google Images, then click on the page that has the image. Some times you find gems!
I found this in two seconds! Did your search include XXX like usual?
AND Strings are hard to measure (Delta p)(Delta x) =h/4pi![]()
I wasn't going to mention this, but since you are in a mood: the original "helpful" link I provided was the first result of a Google search for "Tecumseh Vector Engine". That's why I was thinking you had obviously seen it.
