Tecumseh Vector carb
Oh...so sorry...I forgot you guys can't read titles! It's a TECUMSEH VECTOR CARBURETOR!
You think you can find two that are differently assembled internally? (correctly? )
I'll settle for ANY Vector breakdown!
I assume you have looked at this and concluded your's is from a different Tecumseh dimension?
http://outdoorpowerinfo.com/repairs/tecumseh_vector_carb.asp
Nope....if I had found that...I wouldn't have been asking for a breakdown. Even though that doesn't show a breakdown...it showed me enough. Thanks for the help!
It's the same old dilemma now....new one is on the way,(hopefully the correct replacement,) because buying replacement Tech carbs costs about $1 more than a kit!
The O rings were shot in the one I had....I didn't even know there was one at the end of that drain assembly! And...I didn't have it assembled correctly...(the emulsion tube/spring...)
Atlanta, GA
Working on Tecumseh motors is it's own reward, that is: blood, sweat and pain, all for next to nothing. I respect anyone who is a fan of them, because that's crazy.
Yeah...it's not like I have the cash to just go out and buy whole engines. This paticular engine is a good one...industrial grade cast iron sleeved...but mainly, it's sitting on a DR brush cutter that has a chainsaw blade on it....soooo...the profit potential is there.
Not only are Tecrapsey's fickle...(pretty much just the carbs)... but the part#s are FUBAR as well ....at least to me!
I'm only into this thing for $40...+$15 for a new carb (if it's the right one?????) Then if everything works...I can look into a battery (and hope the starter works! )
If I had the string trimmer head for it...I might even keep it...and use it to mow my scumbag neighbors lawn...(Who thinks you only need to mow the front once a month....and the back when the city makes you!):mad2::mad2::2guns:
zbuck
Ft. Wayne, IN
:wai: Good move on a new carb, as I have found that trying to rebuild that type of carb is useless.
That link is on the Helpful Links sticky. Looks like you were doing a freerunner by not searching :D:D
I was searching the net...it didn't occur to me to search here because it's a vertical shaft engine it's on.
But it wasn't a FreeRunner move...I was asking for information I was having trouble locating, not ignoring advice and cobbling something up.
http://www.tecumsehcarburetorguide.com/tecumseh-parts/
"Another best part about the guide offered by us is that you can see in-depth parts detail of every Tecumseh carburetor that is available. "
Not sure if this helps. Lots of carbs in this one. Now Break It Down! -MC Hammered
---------- Post added at 01:24 AM ---------- Previous post was at 01:21 AM ----------
One of my favorite ways to surf the web is to search Google Images, then click on the page that has the image. Some times you find gems!
I found this in two seconds! Did your search include XXX like usual?:roflol:
AND Strings are hard to measure (Delta p)(Delta x) =h/4pi:huh:
So glad you found that nearly useless information so quickly. All that had was a paragraph describing a Vector carb.
For all you guys smart a$$ remarks, nobody ever came up with a breakdown, which is what I was asking for!!! It doesn't matter now, but don't make an A$$ out yourself trying to make one out of me.
BTW: I located a breakdown finally anyway....ON MY OWN.
EDIT : BTW: I had already been to where you linked BEFORE I started this thread! (It's how I figured out it was a Vector carb!)
One last thing: I wish clicking on Google images did something for me....all clicking on them has ever done is make them bigger.
EDIT: (Again! ) Actually, Bob, this has turned out to be the best information I've gotten in a long time!!!! I didn't know to click on the page on images!!!! THANK YOU! !! Gonna make my search life much easier now!
Atlanta, GA
I wasn't going to mention this, but since you are in a mood: the original "helpful" link I provided was the first result of a Google search for "Tecumseh Vector Engine". That's why I was thinking you had obviously seen it.
No..as I said...I hadn't. Sometimes it just takes one word to make a big difference. The link you gave me was helpful. (I had already found Bob's link.)
Now ....here's what's funny : "Tecumseh Vector breakdown " didn't help much. Googling: "Tecumseh Vector Carburetor images " brought a breakdown right up!
Go figure....If I hadn't spent considerable time hitting dead ends..I wouldn't have asked for help.
I think part of the problem was it took a long time just to figure out it was a Vector carb!
