danable
Working on a model 135202 and the main jet is clogged. Purchased a rebuild kit and it has a main jet in it but I was told by a local guy that the main jet in these motors is not removeable. Is this true?
Thank you very much. One more question and please forgive my terminology I'll be using if it's incorrect. The plate that is bolted down on the fuel pump diaphragm is corroded in the area under one of the small flappers. I'm assuming the diaphragm needs to seal up against that and it's not able because of the pitting. Would this prevent the motor from running properly ?
Ok. I have a second motor with a pump that's in good shape. I'm gonna swap them out just to see the difference before I do the boil. I appreciate all the help you guys.
Outer plate of the pump, so I'll be using the one that is not corroded and a new gasket. Just to see if it makes a difference before I boil the carb in lemon juice.
Thanks for the help Zbuck. I've decided to just put a predator 6 1/2 horse. I may go pick it up today if I have time. Just wondering what's the easiest way to connect throttle cables to them. Since they have a hand throttle like you would use on a log splitter or something similar, not a cable and pedal like a kart.
Thanks again guys. I picked up the motor and see its going to be quite easy. I had just assumed it only had the hand throttle and no return spring. I can see why so many people just pick this thing up. I think I was at $130 something with tax.
